Whining Inducer - HVAC - DIY Chatroom Home Improvement Forum
Old 04-05-2020, 09:58 AM   #1
Rewards Points: 28
Whining inducer
When the inducer motor runs it has a high pitch whine to it. Can I lube the motor? Or is it from the inducer blower wheel?
ahuangsolo is offline   Reply With Quote
Old 04-05-2020, 10:07 AM   #2
Rewards Points: 732
Re: Whining inducer
Probably the motor bearings.
Post a video of the noise.
roughneck is online now   Reply With Quote
Old 04-05-2020, 10:08 AM   #3
Rewards Points: 54
Re: Whining inducer
Best off replacing inducer before it locks up fully.
Brian085 is offline   Reply With Quote
Old 04-05-2020, 10:59 AM   #4
Rewards Points: 28
Re: Whining inducer
Was figuring out how to post videos. Hope this works. Here it is:
Old 04-05-2020, 12:48 PM   #5
user_12345a's Avatar
Rewards Points: 56
Re: Whining inducer
ya it doesn't sound good.
time for a new inducer - for that one you may be able to get the wheel and motor separately at lower cost than whole assembly.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
Old 04-05-2020, 06:56 PM   #6
surferdude2's Avatar
Rewards Points: 902
Re: Whining inducer
If you're mechanically inclined, take it off and see if the blower wheel is scraping on the housing or the screws that hold the motor. I've seen that a time or two. Loosening the set screw and recentering the blower wheel on the shaft ever so slightly is an easy fix.
I offer than based on my hearing of that video you made... it sounds like metal to metal scraping to me. My high frequency hearing isn't all that keen though so maybe I'm missing something.
Anyway, worth a look... those I fixed that way are still running and it has been over 10 years. I think it was due to natural wear on a thrust washer and too close of an install from the factory but warned the users that the bearing might be going out. One of those repairs was for a friend and ever time I see him now he gives me a shout out about how that bearing is still alive and doing well. LOL
surferdude2 is offline   Reply With Quote
Old 04-05-2020, 07:21 PM   #7
Rewards Points: 902
Re: Whining inducer
TIP: Easy way to diagnose what I mentioned is to press on the end of the motor shaft (some you can get to, some not) with a screwdriver while it running to move the shaft inward a small bit. If the sound goes away, it's fixable by adjusting.
