Where To Buy The Original Or Compatible Solenoid Coil For My Heat Pump? - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Like Tree2Likes
Old 07-22-2020, 04:06 PM   #31
Rewards Points: 714
Re: where to buy the original or compatible solenoid coil for my heat pump?
No, there is no communication to speak of.
It’s basic electrical inputs.
And the air handler is the voltage source. The thermostat handles start/stop duty. Save for the defrost control board in the outdoor unit.
roughneck is offline   Reply With Quote
Old 07-22-2020, 04:18 PM   #32
Rewards Points: 171
Itís basic electrical inputs.
Yes, you are right. I should say "connect", "electrical signal".
"Save for ", what does this mean?
diy001 is offline   Reply With Quote
Old 07-22-2020, 04:24 PM   #33
Rewards Points: 714
The defrost board can turn the electric heat on when the unit goes into a defrost cycle.
However, the control voltage for the outdoor unit comes from the air handler, and not the disconnect outside.
Old 07-22-2020, 04:41 PM   #34
Rewards Points: 171
The transformer provides 24V to the system. Is it possible that the transformer is bad and causes the fuse blowing? The service guy caused a short once in the indoor unit. That short may cause damage to the transformer or other related parts?
Old 07-22-2020, 05:23 PM   #35
Rewards Points: 714
Probably not.
Definitely not, if your suggesting replacing the transformer to see if the problem goes away.
Sounds like your service guy is better at causing problems then fixing them.
Old 07-22-2020, 05:45 PM   #36
An old Tradesmen
Rewards Points: 50
If the transformer was bad, it would burn itself up.
Old 07-22-2020, 07:29 PM   #37
Rewards Points: 171
If the outside unit is power off, do these 24v wires connected to it still work? if not, then that 24v control board will have much less workload or chances to be blown. Am I right?
Old 07-22-2020, 07:44 PM   #38
Rewards Points: 714
No, that is not right.
The indoor board isn’t the problem.
As we have said previously, the 24V circuit is powering the outdoor unit irregardless if the high voltage power is on or off.
Old 07-22-2020, 08:55 PM   #39
An old Tradesmen
Rewards Points: 50
Doesn't matter if the outdoor unit is turned off or not. The thermostat still sends out the control voltage to it, which originates from the indoor unit.
The indoor unit supplies all of the low voltage, the outdoor unit doesn't provide any low voltage itself.
