What Is A Reasonable Indoor Temp For Hot Weather? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree42Likes
Old 06-22-2020, 06:49 PM   #16
Rewards Points: 322
Re: What is a reasonable indoor temp for hot weather?
Originally Posted by SeniorSitizen View Post
If your elect. rate is 12-13 cents / kw i want a cooling unit just like yours.
He's at 705 feet altitude?
Mike Milam likes this.
Nik333 is offline   Reply With Quote
Old 06-22-2020, 06:57 PM   #17
Mike Milam's Avatar
Rewards Points: 66
Yep, Elevation: 705′
Nik333 likes this.
Thank a police officer for being the one who runs 'TO' a report of shots fired, while everyone else runs 'AWAY'
Mike Milam is offline   Reply With Quote
Old 06-22-2020, 07:00 PM   #18
Rewards Points: 322
I feel like I'm stalking you.
Old 06-22-2020, 07:06 PM   #19
Mike Milam's Avatar
Rewards Points: 66
Old 06-22-2020, 07:32 PM   #20
Rewards Points: 248
I'm less than 6 ft.
My house is 1,312 ft. and i don't live on a mountain.
EDIT: EDIT:
Old 06-22-2020, 07:39 PM   #21
Guest
Rewards Points: 4
It supposed to be mid to upper 90's this week in Georgia. I have my A/C set to 77 and use ceiling fans. A very slight breeze makes a world of difference. Any kind of fan is useful . . . and it saves energy & $$.
JARega is offline   Reply With Quote
Old 06-22-2020, 08:13 PM   #22
Missouri Bound's Avatar
Rewards Points: 4,162
What is a reasonable, energy efficient expected indoor temperature with A/C? I know comfort is individual.
A national survey said that men prefer 72 while women prefer 73.
A reasonable indoor temperature is one that you are both comfortable living in and comfortable paying the bill for.
Nik333 likes this.
Do you want it your way or the right way?
Old 06-22-2020, 08:39 PM   #23
Rewards Points: 322
I read that a cooler temp at night helps with good sleep. I've been trying it & it seems to be true.
Old 06-22-2020, 08:44 PM   #24
That is absolutely true. I had a home that did not have central HVAC.
I had a window air conditioner and a fan in the bedroom, kept it pretty cool on the hottest nights. A couple of blankets and sleeping like a baby was the norm.
Nik333 likes this.
Old 06-22-2020, 08:50 PM   #25
Rewards Points: 2
70 degrees pretty much year round. During the short winter we keep the heat at 65 while we sleep
Nik333 likes this.
BayouRunner is offline   Reply With Quote
Old 06-22-2020, 10:51 PM   #26
Rewards Points: 5,128
I didn’t mention cost. We keep the house at 72 day and 68 night, and the 1800 square foot shop at 65 all the time. Projects are actually fun in hot weather. In a hot month, which we only get about 3 per year, our bill is $150 to maybe $175. Our heat bill in a brutal NY winter month is occasionally as high as $100. It is all about insulation and good windows, they have paid for themselves many times over. R25 walls, R50+ ceilings, overlapping layers for wind resistance, good attic ventilation and Andersen windows, with good heating and cooling equipment. We spent the money up front and saved for 40 years.
Nik333 likes this.
Old Thomas is offline   Reply With Quote
Old 06-23-2020, 02:28 AM   #27
Rewards Points: 1,542
I've always been told the best you can expect is 20 lower temp inside vs. outside. That may be BS? Not sure.
I can tell you we keep ours set at 68 year round. We have had several 90+ days so far and ours kept the inside 68.
I pre-cool mine in the mornings before power prices go up, then set back to 77F, but if it gets over 50% humidity the thermostat will kick in the AC a bit early.
102F, Dew Point 61, RH 26%, Indoor - 81F. Cranked up all the way. I think the freon may be low. It was on all night, also.
depending on the house/sun/insulation/tonnage, etc. that might be excellent. or not.
cranked up all the way means on not off?
most systems only have one power level.
or insulation like theirs.
u3b3rg33k is offline   Reply With Quote
Old 06-23-2020, 05:26 AM   #28
An old Tradesmen
Rewards Points: 58
Temp delta depends on how it was sized.
Most grocery stores can maintain 68 inside when its 100 plus outside.
Old 06-23-2020, 06:48 AM   #29
I'm less than 6 ft.
EDIT: EDIT:
Move before the caps melt. You will be in a world of hurt when they do.
SeniorSitizen likes this.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is offline   Reply With Quote
Old 06-23-2020, 06:56 PM   #30
Apples and oranges.
Grocery stores also have a vast amount of coolers and freezers to contribute to cooling and lessen the load. Many of the stores have "warehouse" ceiling and the air stratifies. They only have to cool the lower 8'. They also are build on concrete several inches thick with concrete block wall. That mass takes a long time to warm or cool but once it does it is the key to keeping the temperature moderated year round. And the cooling portion for those stores is 80% of their energy consumption.
The Following User Says Thank You to Missouri Bound For This Useful Post:
Nik333 (06-23-2020)
