What About Oversizing An AC That Has A Variable Motor? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-22-2020, 11:26 PM   #1
Rewards Points: 216
What about oversizing an AC that has a variable motor?
I think I know the main reasons of why not to usually oversize on an AC. It won't dehumidify, the condensor won't be on long, and will keep cycling, but what about getting a larger AC condensor if its one of these expensive models with a variable condensor motor.
My sleep schedule just fluctuates and I like to crank it down from 75 to 67 when I do. I especially do this in the summer time when its 110+ out and I can accomplish more when its cooler out.
If my house would be sized right for 2 1/2 or 3 ton, and lets say I could get a good deal on a 4 or even 5 ton, would that work?
wthdideyedo is offline   Reply With Quote
Old 08-22-2020, 11:52 PM   #2
Rewards Points: 716
Re: What about oversizing an AC that has a variable motor?
It’ll be very expensive redoing all your ductwork to fit that 5 ton unit you got a “good deal” on.
roughneck is offline   Reply With Quote
The Following User Says Thank You to roughneck For This Useful Post:
wthdideyedo (08-22-2020)
Old 08-22-2020, 11:55 PM   #3
Rewards Points: 216
Certainly didn't think of sizing the ductwork. That sounds good enough to kill the deal. Thanks.
Old 08-23-2020, 07:53 AM   #4
Rewards Points: 618
You could be filling the inside of your walls with mold by having a setpoint that low. The colder your walls are, the higher the chance that outdoor humidity could be attracted to them.
A Variable speed compressor, coupled with a variable speed indoor fan and a communicating thermostat CAN dehumidify better than a standard system, but it's still not good to oversize, and the thing about the ductwork is something that many people overlook.
bfrabel is offline   Reply With Quote
