Ventless Vs Vented Gas Burner Fireplaces - HVAC - DIY Chatroom Home Improvement Forum
Old 05-01-2020, 12:08 PM   #1
Rewards Points: 2
Ventless vs Vented Gas Burner Fireplaces
I want to put a gas "contemporary glass" burner into a wood burning fireplace (my fireplace already has gas run to it).
Should I use a vented or a vent-free burner?
ClarkLG is offline   Reply With Quote
Old 05-01-2020, 12:22 PM   #2
Rewards Points: 772
Re: Ventless vs Vented Gas Burner Fireplaces
Ventless can be dangerous and are outlawed in many areas due to safety concerns.
With ventless, you should not use the fireplace for a primary heat source and should open a window or door while it’s operating.
roughneck is online now   Reply With Quote
The Following User Says Thank You to roughneck For This Useful Post:
ClarkLG (05-01-2020)
Old 05-01-2020, 12:32 PM   #3
user_12345a's Avatar
Rewards Points: 116
stay away from vent free fireplaces, they should not be legal.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
The Following User Says Thank You to user_12345a For This Useful Post:
Old 05-01-2020, 02:34 PM   #4
Rewards Points: 5,278
If you read and follow the listing for a vent free unit you will have a small unit in a large room with a window open. No matter how clean it is supposed to be, you will be breathing the products of combustion. I recommend a vented unit.
Old Thomas is offline   Reply With Quote
Old 05-01-2020, 03:39 PM   #5
sktn77a's Avatar
Rewards Points: 1,030
Neither are a particularly good primary heat source (the vented sets send a lot of heat out the flue and the ventless sets will put a lot of CO2 and water vapor into the room). If it's just for aesthetics, either will work. If it's a backup heat source (again, for occasional use only) the ventless sets are more efficient.
Ventless sets are prohibited in bedrooms.
sktn77a is offline   Reply With Quote
Old 05-01-2020, 11:20 PM   #6
Rewards Points: 116
For aesthetics, can always go for an electric fireplace and keep the heat off.
Tags
fireplace , gas fireplace , gas fireplace vent , vented fireplace , ventless fireplace
