Using Blower Fan - HVAC - DIY Chatroom Home Improvement Forum
Old 04-25-2020, 01:54 PM   #1
Rewards Points: 220
Using Blower Fan
So a company was replacing a HVAC system near me recently and I was able to harvest the Squirrel Cage fan which they said was still good. I want to wire it to use as a patio "fan" to simply move air when the temp is hot. The fan has 2 brown wire and 1 each red,blue, black, orange and white. I am assuming the fan is 110 volt ac. Which three wires should I use for power?
wpollock is offline   Reply With Quote
Old 04-25-2020, 04:48 PM   #2
Rewards Points: 732
Re: Using Blower Fan
Shouldn’t assume it’s 115V, many are 208/230V.
This isn’t a great choice for a circulation fan.
roughneck is online now   Reply With Quote
Old 04-25-2020, 09:12 PM   #3
Upload a pic of the motorís tag. Should have a diagram on it
jmal1031 is offline   Reply With Quote
Old 04-29-2020, 07:28 PM   #4
dj3
Rewards Points: 180
You want to use an A/C forced air fan in a patio?
Wrong application.
dj3 is online now   Reply With Quote
Old 04-29-2020, 07:30 PM   #5
user_12345a's Avatar
Rewards Points: 60
The motor will over-amp if the blower operating without restriction - you'll have to restrict the intake a bit.
best to just buy a box fan or something.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
