Used R410a Risks - HVAC - DIY Chatroom Home Improvement Forum
Old 06-04-2016, 03:09 PM   #1
Rewards Points: 444
Used R410a risks
I just bought a tank of r410a off a guy who answered my craigslist ad. He wanted 120 dollars.. He said it was brand new but he had used a few pounds. He answered my ad because he said he has been there before.
I got it home and now I'm wondering if I was scammed..
It weighs just over 25 lbs.. The bottom feet are scuffed and the top is scuffed around the rim. I'm guessing it could have been rattling around in his car..
What are the chances this was his recovery tank?
Used R410a risks-image_1465070547580.jpg   Used R410a risks-image_1465070588953.jpg   Used R410a risks-image_1465070611198.jpg   Used R410a risks-image_1465070633034.jpeg   Used R410a risks-image_1465070660757.jpg
zootjeff is offline   Reply With Quote
Old 06-04-2016, 03:19 PM   #2
Rewards Points: 444
He said he was working on the commercial system at a grocery store and had an un-logo'd white van with hvac gear in it. I know it is compressed gas..
Old 06-04-2016, 03:34 PM   #3
Rewards Points: 568
Re: Used R410a risks
New tank weighs 33lbs give or take a few ounces. I'd be scared to use one as a recovery tank. Pretty good chance you would blow the safety. I'd say its a legit sale. Hopefully not selling his bosses refrigerant
BayouRunner is offline   Reply With Quote
Old 06-04-2016, 03:44 PM   #4
Rewards Points: 272
I'm pretty sure all the non-recovery tanks have check valves so you can't use it as a recovery tank,
BTW, anyone in the US can buy a jug of R410a, no- EPA cert is needed for it.. Unless you have a cert, I don't know of a local supply house that will sell it, but online, they're a dime a dozen. Around me, at the supply houses sell the 25lb cylinder for about $125.. I'm pretty sure you can get it for about there online too, delivered. It was cheaper a couple months ago, but with cooling season, I think they all jacked the price up.
crabjoe is offline   Reply With Quote
Old 06-04-2016, 04:05 PM   #5
user_12345a's Avatar
Rewards Points: 3,076
wonder if u can bring it over the boarder.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old 06-04-2016, 04:22 PM   #6
Rewards Points: 907
Crabjoe is right, You can't use that bottle to recover ref.
Bitters is offline   Reply With Quote
Old 06-04-2016, 04:31 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 1,584
A recovery tank looks totally different. It is very heavy built and has 2 valves. Gas and liquid plus your disposable one has a built in check valve so it cannot be refilled.
Old 06-04-2016, 04:41 PM   #8
Rewards Points: 1,236
To reiterate crabjoe, you can buy a new 25 lb bottle online. Today from Amazon pricing is $132.40.
bfletcher7 is offline   Reply With Quote
Old 06-04-2016, 05:31 PM   #9
Rewards Points: 1,022
Can't use that as a recovery tank, the valve has a check built into it.
You'd probably gotten a better deal just buying a new bottle.
roughneck is online now   Reply With Quote
Old 06-04-2016, 11:08 PM   #10
An old Tradesmen
Rewards Points: 9,856
Slim to no chance its was his recovery tank, as it would most likely blow the relief using that jug for recovery.
It may be stolen though, as in it was probably his bosses refrigerant he sold you.
Old 06-05-2016, 01:10 AM   #11
Rewards Points: 444
Thanks for the replies everyone. I loaded 4lbs 6 oz into my system and it works great! I went from 26 lbs to 21ish. Thanks for the all the insights!
-Jeff
Old 06-05-2016, 06:21 PM   #12
-Jeff
fix the leak?
Old 06-06-2016, 12:18 AM   #13
Rewards Points: 444
Originally Posted by user_12345a View Post
fix the leak?
Yes, I was not good at the 1/4 flare tool on my first couple flares, even though I did about 15 test flares, and I noticed it was a little cockeyed when I first did it. It held 250psi nitrogen previously, and a 600 micron vacuum. and it ran for weeks cooling. This weekend it didn't cool at all. I tested the schrader and got nothing. Put in a little nitrogen and then bumped the flare fitting and got the bubbles. Re-did the flare, ran a 150psi Nitrogen purge. Bought a new vacuum pump, pulled a vacuum. Took much longer pulling the entire outdoor unit.. But then when it held a vacuum, it held it rock solid. Before when I'd throw the valve it would creep back up but then settle out. This time it held the same value without moving for an hour. The pump was only able to get about 1000 micron. Then I weighed it in. Working like a charm.
Old 06-06-2016, 12:58 AM   #14
Rewards Points: 80
Some of the vacuum pumps have multiple ports on them. (different sizes) Make sure that the caps are tight, as they can cause a poor vacuum.
If it held at 1000um then you should be fine, even if it's a tad high.
PS. Flares take quite some practice to get right every time. They look easy, but they are just as easy to mess up. Don't sweat over it.
Cheers!
supers05 is offline   Reply With Quote
How to convert existing R22 system to R410A pointedspider HVAC 39 03-25-2017 08:32 AM
Charge HVAC R410a as a Gas? statum1012 HVAC 22 10-18-2013 05:18 PM
R410a acessories JJboy HVAC 4 05-25-2011 08:10 PM
Which works better - R410a or R22 HP/AC kb3ca HVAC 7 08-17-2010 07:50 PM
is a charging R410a same as R22 LLB62777 HVAC 8 04-08-2010 05:40 AM
