Upgrading To Honeywell T5 Wifi Smart Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 06-09-2020, 09:49 AM   #1
Rewards Points: 44
Upgrading to Honeywell T5 wifi smart thermostat
Hi all,
I am planning to upgrade my thermostat to a Honeywell T5 smart wifi unit and I have a couple of questions that I hope someone can help with. My current setup does not have a "C" wire installed however I do see four additional wires available.
Questions:
1. Can I use one of the four available wires for the "C" connection? Please refer to the images in this post. For example, can I splice the orange wire and connect this to the "C" port in the thermostat?
2. Do I need a jumper cable for "Y" and "G" so the blower fan will turn on? Currently, I do not see any jumper cables and the blower fan comes on whenever the central air conditioning is running
Upgrading to Honeywell T5 wifi smart thermostat-wall-thermostat.jpg   Upgrading to Honeywell T5 wifi smart thermostat-attic-board.jpg   Upgrading to Honeywell T5 wifi smart thermostat-wires-attic.jpg
wchang is offline   Reply With Quote
Old 06-09-2020, 09:52 AM   #2
user_12345a's Avatar
Rewards Points: 56
Re: Upgrading to Honeywell T5 wifi smart thermostat
You have enough wires to do it right so you can leave G alone.
Yes, you can use a spare wire - leave the existing wire on C and slip the one going to the t-stat under the same terminal.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
Old 06-09-2020, 10:00 AM   #3
Rewards Points: 44
Great thanks for clarifying. As for the current white wire on the "C". Is this from the condenser?
All I need to do at this point is splice any available wire such as the orange color, unscrew to loosen the "C" connecter, and position the orange wire into the "C"?
Old 06-09-2020, 10:03 AM   #4
Rewards Points: 56
Yes, it's from the condenser.
Yes - just use any wire, connect to C at stat and control board.
