Unions On PVC Furnace Flu? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-19-2016, 05:59 PM   #1
Rewards Points: 444
Unions on PVC furnace flu?
I need to service my furnace and I need to cut the 2 inch pipe away temporarily to get out the blower I was wondering is it code to put a union on the inlet and outlet air pipe for the combustion blower?
zootjeff is offline   Reply With Quote
Old 11-19-2016, 06:59 PM   #2
Rewards Points: 80
Re: Unions on PVC furnace flu?
No
Cheers!
supers05 is offline   Reply With Quote
Old 11-19-2016, 08:05 PM   #3
Rewards Points: 80
If you cut the pipes, you have to reglue with couplings. The fresh air is usually not glued at the furnace collar. The venting will have a rubber coupling. Sometimes gluing is all you can do. Don't forget to use the right stuff. It's 636 or similarly certified.
Cheers!
Old 11-20-2016, 05:53 AM   #4
An old Tradesmen
Rewards Points: 9,856
Unions are not uncommon in the USA.
Old 11-20-2016, 10:17 AM   #5
Rewards Points: 80
Really? Interesting. It's completely illegal here.
Cheers!
Old 11-20-2016, 11:52 AM   #6
Rewards Points: 444
Can you post a code reference that would suggest it's illegal? Do they call it out specifically or did they just say general terms that lead you to believe it's not?
if you torque the union properly I bet it does a better seal than RTV or silicone people use to seal off the furnace flange to the PVC..
Old 11-20-2016, 03:12 PM   #7
Rewards Points: 80
Because it's special venting. You'd have to find a union rated at 636. Every inspector I've ever spoke to won't even think twice about it.
Silicone isn't 636 rated either BTW.
Cheers!
Old 11-21-2016, 03:25 AM   #8
An old Tradesmen
Cheers!
USA hasn't gone to 636 yet. At least not across the nation.
Old 11-21-2016, 05:51 AM   #9
Rewards Points: 80
Ah. Good to know. Hard to keep all the rules straight everywhere.
Cheers!
trouble wiring furnace with single zone relay for circulator btomassacci HVAC 4 12-05-2014 07:08 AM
Is this a furnace problem? joannie HVAC 31 11-16-2014 09:00 PM
Connect AC to Central Air Furnace MaxOvrdrv HVAC 42 05-16-2014 09:50 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
