Unbelievable, Thermostat Setting Changes By ITSELF - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-20-2014, 05:17 PM   #31
Rewards Points: 582
ok then after all the comments here..we all agree replace the t stat...ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
hvactech126 (01-20-2014)
Old 01-20-2014, 05:37 PM   #32
Hvac Pro
yuri's Avatar
Rewards Points: 196
I dunno, Have to check the ole crystal ball. Could be a episode of "The Zone" Bwahahaha
Old 07-17-2014, 11:06 AM   #33
same thing only worse
okay dokie, regular window unit. model number.FAC127S1A
ya i should have started a new thread. w/e .. anyways
the thing constantly changes from "cool" to "energy saver" to "fan only" some times really fast like a constant sequence of "beeps".. sometimes just one or two beeps (beep meaning it changed settings). and it only does this in the area that controls those three settings. the Temperature doesn't change nor does the fan speed.. the friggin thing will wake me up in the middle of the night with a flurry of beeps and i have to refrain from tearing it out of the wall only because there would be a hole in the wall, plus no ac in FL.... but i think im getting close to understanding what's going on here... either there is a short. ie dust build up on the board. or it wasn't wired right to begin with..or i need to find the circular battery thats on one of the boards .. one of those 2032 batteries and replace that i have the thermostat chip hanging out by the wires so i can press the buttons on the actual board instead of having the plastic cover over it because i thought the case was fitting too tight and maybe that was the prob but nope.. still ghost changes with it off.. soooooo replace the thermostat?
bradentucky is offline   Reply With Quote
Old 07-22-2014, 07:03 AM   #34
unbelievable thermostat
By chance have you ever figured out what the problem was? We have the same exact thing happening at our house.. Love how people jump to a conclusion with out knowing the truth or facts. Im very interested in your findings.. Thanks
Schmitt03 is offline   Reply With Quote
Old 07-24-2014, 01:31 PM   #35
thermostat with its own mind
We also have the same problem...our thermostat on the AC changes itself with a continual barrage of beeps...help!
Relosach is offline   Reply With Quote
Old 07-24-2014, 03:19 PM   #36
Hvac Pro
yuri's Avatar
Rewards Points: 196
Electronic thermostats can go haywire/malfunction just from age. Average life is 10 yrs.
Mechanical thermostats should not change their setpoint unless the mechanism inside is very loose. The heat anticipator should not be creating enough heat to expand it. If it is then you have a serious current draw problem from the gas valve.
Get a new Honeywell Focus Pro thermostat from HDepot.
Old 07-25-2014, 03:34 AM   #37
Thanks Yuri, but I live in Taiwan...no HDepot here and probably no Honeywell Focus Pro thermostat...time to call the technicians in....thanks again!!!
Old 07-25-2014, 03:37 AM   #38
Our AC went bonkers when the typhoon hit the other day....and has been bonkers since...
Old 07-25-2014, 08:38 AM   #39
Hvac Pro
yuri's Avatar
Rewards Points: 196
Probably had a power surge and it damaged the circuit board.
Old 06-12-2020, 12:50 AM   #40
My thermostat ( manual thermostat) is changing temperature settings on it's own aswell. Came home this evening and thermostat was set at 90%. I live alone. All doors locked. 😕
Deborah Peel is offline   Reply With Quote
Fan setting reads AUTO and ON at same time on Honeywell 8500 thermostat Studly HVAC 1 03-21-2011 08:27 PM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 04:32 PM
Burner always stops at LOW setting on L8124L pleasehelpmike HVAC 2 01-19-2011 08:22 AM
Least expensive Programmable Thermostat for home with automatic vacation setting Studly HVAC 2 12-15-2009 07:18 AM
A/C not cooling to thermostat setting? stephgpdiy HVAC 11 08-21-2009 07:00 AM
