Two Story House With Two A/C Units Question About Supply Vent Location - HVAC - DIY Chatroom Home Improvement Forum
Old 08-24-2020, 01:15 PM   #1
Rewards Points: 2
Two story house with two A/C units question about supply vent location
I have a two story home in central Texas, with a 2 ton unit (Downstairs) and a 2.5 ton unit (upstairs) the first floor and second floor are closed off to each other other then the stairwell with a thermostat on each floor.
My question is why is there a supply vent directly above the stairs landing that blows down the stairs?
The reason for this question is I'm planning on install a whole home dehumidifier and I was thinking I could make the current supply vent above the stairs landing as the inlet to the dehumidifier.
Will my Idea work?
I do A/C maintenance but never messed with duct locations.
Kraylon is offline   Reply With Quote
Old 08-25-2020, 09:04 PM   #2
An old Tradesmen
Rewards Points: 122
Re: Two story house with two A/C units question about supply vent location
To fight the hot air rising up the stairs.
It should work, but your A/C may have some troubles without that supply.
Old 08-25-2020, 09:07 PM   #3
user_12345a's Avatar
Rewards Points: 92
Don't eliminate supplies or returns, nothing good comes from that - add what you need for the dehumidifier.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
