Two Air Compressors Out - HVAC - DIY Chatroom Home Improvement Forum
Old 06-15-2020, 08:44 PM   #1
Rewards Points: 42
Two air compressors out
The air compressors for the upstairs and main level went out today. Both units are around the same age but I doubt both units would go out at the same time. I flipped the inside breaker switches on and off and still nothing from the compressors. The inside units still blow air. But the fans on the outside compressors aren't turning. I also flipped the outside switches that are above the 2 outside compressors and still nothing.
Is there anything else I can check?
clay1g1 is offline   Reply With Quote
Old 06-15-2020, 09:30 PM   #2
Rewards Points: 902
Re: Two air compressors out
It's possible that there are fuses in the outdoor unit electrical disconnects. If so, it's very important to know what you are doing when checking them.
57TinkerMan is offline   Reply With Quote
Old 06-15-2020, 09:35 PM   #3
Rewards Points: 724
Are the outdoor units getting a call to run? Is there high voltage to the units?
Use your meter to check.
roughneck is offline   Reply With Quote
