Trane XE1000 Contactor - HVAC - DIY Chatroom Home Improvement Forum
Old 03-22-2017, 06:11 PM   #1
Rewards Points: 4
I have a Trane XE1000 2.5 ton AC on a rent house I own. The contactor is sticking closed causing the condensor to keep running after the thrmostat has turned the AC off. I took a picture of the contactor so I could match it at the parts store. But then I noticed something a little off in the picture - the wiring looks jerry-rigged, which makes me wonder if maybe it's the wrong contactor for this unit and they rigged it to make it work. (See attached pic)
DAKAVAJO is offline   Reply With Quote
Old 03-22-2017, 07:42 PM   #2
Rewards Points: 1,856
Re: Trane XE1000 Contactor
Looks ok to me. What looks rigged?
Just a plain, run of the mill 30 A single pole 24 V contactor
roughneck is online now   Reply With Quote
Old 03-22-2017, 08:34 PM   #3
Hvac contractor
Rewards Points: 578
well for one thing, I don't think thats the right contactor.
someone replaced a double pole 240v/24v contactor with a single pole.
Not a really big deal. Im going to guess the 'other leg' is simply wire nutted together.
I would suggest a 2 pole, 240v/24v ENCLOSED contactor. These contactors will keep bugs and other things out that make the thing stick.
can you get a picture of the wiring diagram from the Service facts sheet, it should be folded up inside the electrical compartment
jeff00 is offline   Reply With Quote
Old 03-23-2017, 06:19 AM   #4
Rewards Points: 4
Look at the red wire. They split the sheathing and pulled out 2 strands of copper and wrapped them around the connector on the side.
Old 03-23-2017, 06:24 AM   #5
You sure the red wire isn't just touching the contactor, and the copper is the contactor wiring going into the coil?
Old 03-23-2017, 06:52 AM   #6
Hvac contractor
Rewards Points: 578
agreed, thats just the coil wire wrapped around the terminal
move the red wire and I bet thats the case
Old 03-23-2017, 08:22 AM   #7
Rewards Points: 4
Oh....Maybe so. In another picture it looks like the sheathing is torn on the back side of that wire, but maybe that's just from rubbing against that terminal. I'll check it this afternoon when I get home. Thanks!
Old 03-23-2017, 08:30 AM   #8
Rewards Points: 4
Here's a better picture of the contactor from the top so you can see all the connections.
Old 03-23-2017, 05:19 PM   #9
An old Tradesmen
Rewards Points: 7,828
Thought those came with a single pole contactor.
Old 03-23-2017, 06:10 PM   #10
Rewards Points: 4
Thanks for the help. Went to supply today & got new single pole contactor. Heading over to install it now.
Old 03-23-2017, 08:44 PM   #11
Hvac contractor
Rewards Points: 578
my bad, you are correct. It's been awhile since I have seen one of those.
Old 03-24-2017, 06:12 AM   #12
Rewards Points: 4
Installed new contactor and problem is fixed. You were right about the wire being from the coil. And I took your advice and made sure I got a fully enclosed contactor. Thanks again! This was my first time using DIY Chatroom. I'm sure I'll be back.
outdoor fan w/ an attitude - trane ex1000 model twr030c100a3 sacrilege HVAC 12 11-12-2015 10:05 PM
Trane XR13 Contactor Bad? sourkraus HVAC 27 03-13-2014 02:36 PM
Trane XE1200 Tripping inside breakers even after contactor replacemnt strainstress79 HVAC 5 04-14-2013 11:24 AM
Trane XE1000 Troubleshooting Lack of Heat Hookemdevils22 HVAC 9 01-24-2013 05:56 AM
Trane XE1000 compressor not coming on line. Flathead64 HVAC 8 11-03-2009 06:29 PM
