Trane Xb10 Hard Start Capacitor Started On Fire - HVAC - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By BayouRunner
Old 08-26-2017, 08:06 AM
Rewards Points: 4
Trane xb10 hard start capacitor started on fire
What would cause my Supco Hard Start CAP to start fire on my Trane XB10 Heat Pump? I have had capacitor problems in the past but nothing like this. Trane xb10 hard start capacitor started on fire-hard-start-wiring.jpg
duensingm is offline
Old 08-26-2017, 08:58 AM
Rewards Points: 1,080
Re: Trane xb10 hard start capacitor started on fire
It was wired wrong or a power surge ( lightning).
Wilbits is offline
Old 08-26-2017, 10:24 AM
Rewards Points: 4
It was a crystal clear day around 10am and I also have a surge protector installed.
Old 08-26-2017, 11:04 AM
Rewards Points: 1,096
those kits have a device at the top that take the capacitor out of the circuit after startup, it's a ptc device that gets very hot, resistance goes way up and it restricts current flow.
looks like it failed in a bad way.
WARNING: I am not in the business of any trade or topic I give advise on. Follow advice at your own risk. I have previous diy experience plus good knowledge of theory.
user_12345a is offline
Old 08-28-2017, 02:16 AM
Rewards Points: 70
They use a relay to disengage the capacitor. It either stuck closed, or started to cycle to often. (it happens) The result is a great demonstration on the disadvantages of using electrolytic caps with AC. Quite spectacular. Not to many models use a thyrister, but they can fail too.
Replace it, double check the current draw of the compressor. Move on with your life.
Cheers!
supers05 is offline
Old 08-28-2017, 09:08 AM
those cheap superboosts don't have a real relay.
they have another product that does as well as a backup timer if the relay fails.
Old 08-29-2017, 06:54 PM
Rewards Points: 70
Took one apart for you buddy....
That looks like a relay kit to me....
Cheers!
supers05 is offline
The Following User Says Thank You to supers05 For This Useful Post:
user_12345a (08-29-2017)
Old 08-29-2017, 07:22 PM
Rewards Points: 496
I've seen a lot of thos two wire ones fail. They actually lock up the compressor when they do. You can remove it and compressor will start right up. I imagine the compressor was trying to start, the relay was stuck in the start position for a long period of time. I have never seen one burn up like that
user_12345a likes this.
BayouRunner is online now
Old 08-29-2017, 07:44 PM
Cheers!
That's the higher end e-series they list. i didn't know they were called superboost as well.
there's a series that doesn't use a real relay - what the op has in the pic, a spp6.
http://www.supco.com/web/supco_live/products/SPP6.html
"Hard Start Kit Positive Temperature Coefficient (PTC) Relay and Start Capacitor SPP Series"
the series that you have a pic of does and sounds like a good product:
http://www.supco.com/web/supco_live/products/SPP6E.html
SPP6E
SPP6E--E SERIES HARD START
Electronic Potential Relay/Start Capacitor Combination Hard Start Kit with electronic timing circuit
Old 08-29-2017, 08:04 PM
Rewards Points: 70
Yes, the E series is the only type that most of the suppliers around here carry.
However, i don't have much issue with the other types. It's extremely mature tech. (old style cathode tube TVs used it for degaussing.)
@BayouRunner I've seen quite a few. New and old compressors. Overall, it's fairly rare compared to the number that are installed. Usually they just vent, but the electrolytic is flammable, so it catches fire sometimes. If the cap is shorted, and the relay stuck, it's essentially shorting across the original cap. In essence, electrically removing the cap, and therefore no start starting torque.
Cheers!
supers05 is offline
Trane XB 13 Start capacitor gmeyer HVAC 7 07-07-2014 05:04 PM
is a hard start kit needed???? firedogut HVAC 3 10-08-2009 06:33 PM
Buying a Hard Start Capacitor Help D1G1T4L3CH0 HVAC 3 10-17-2008 08:42 PM
hard wood fire door crecore Building & Construction 3 11-09-2007 06:35 PM
Hard wired fire alarms keeping going off sdgoss Electrical 6 11-09-2005 08:57 PM
