Trane 80 XE Water Dripping - HVAC - DIY Chatroom Home Improvement Forum
Old 05-22-2020, 10:07 PM   #1
Rewards Points: 8
Trane 80 XE water dripping
Urgently need help. Called the home warranty, someone came and looked at the HVAC and said it is all good. Called roofer, fixed roof vents. Not sure what next. We still have heat on. Had AC on for 2 days but changed it back to heat.
Please suggest. Its in the basement, I hear the small drip of water. Its near the filter at the bottom. I dont have much idea on the hvac.
TIA.
gsmruti is offline   Reply With Quote
Old 05-22-2020, 10:43 PM   #2
user_12345a's Avatar
Rewards Points: 2,094
Re: Trane 80 XE water dripping
So where's the water leaking? do you know? it may not even be a leak, it may not have anything to do with this stuff.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
The Following User Says Thank You to user_12345a For This Useful Post:
gsmruti (05-22-2020)
Old 05-22-2020, 10:46 PM   #3
Rewards Points: 8
I am sorry I dont have idea on hvac. But if u see the image its dripping from down next to the filter but there is no water inside furnace. Its coming from the left side of the pipe that connect to the filter. probably called inlet.
Old 05-22-2020, 10:52 PM   #4
Rewards Points: 8
I am sorry I dont have idea on hvac. But if u see the image its dripping from down next to the filter but there is no water inside furnace. Its coming from the left side of the pipe that connect to the filter. left side of the arrow
Old 05-22-2020, 11:38 PM   #5
surferdude2's Avatar
Rewards Points: 240
I suspect you may have a humidifier leaking water into the return air plenum but I can't see one from that picture. Is there anything mounted on the return air plenum up higher? That PVC lying on the floor looks like it comes from something up higher... perhaps a humidifier drain?
If so, turn the water valve for it off until you can correct the problem. Look on the water pipes serving the water heater to see if there is a small water line tapped off that serves the humidifier. That's where you will find the shut off valve.
Normally a humidifier only gets water when the furnace is in heat mode so running it in cool mode might be OK until you can fix the problem. No guarantee on that.
There's more than one way to skin a Cat. ~ C.L. Best 1878 - 1951
surferdude2 is offline   Reply With Quote
Old 05-23-2020, 01:06 AM   #6
Rewards Points: 8
We dont have humidifier
Old 05-23-2020, 03:52 AM   #7
Rewards Points: 2,560
Perhaps condensate drain is clogged or leaking?
bob22 is offline   Reply With Quote
Tags
trane 80xe water leakage
