Tjernlund Radon Fan Installation - HVAC - DIY Chatroom Home Improvement Forum
Old 03-14-2020, 07:32 PM   #1
Rewards Points: 32
Tjernlund Radon Fan installation
Iím installing a Tjernlund Radon fan , trying to find out how to attach it to a hoist so thereís not much noise or vibration to feel from upstairs. Would doubling the hoist then bolting it be best? Itís right about the sump 9 feet up then the exit will be under a joist then thru the house wall. Enclosed is a picture. Thank you
Anglib56789# is offline   Reply With Quote
Old 03-15-2020, 07:07 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 324
Re: Tjernlund Radon Fan installation
Which way is "UP"? The unit should have come with rubber isolation boots to go behind the metal to help with sound and vibration issues. If not, you can probably buy something soft to put between the wood and metal motor casing frame.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 03-15-2020, 08:26 AM   #3
Rewards Points: 32
Thank, pic is sideways - its a new type fan that exits just out the house. Ill make a box around it, so guess if muffles it. Just didn’t want to put it up and then figure out a better way then take it down again.
Old 03-15-2020, 10:18 AM   #4
Hammered Thumb
Rewards Points: 122
The Tjernlund RadonVac fan indicates that no separate isolation joint is required - the pipe stubs have a rubber isolation joint on each entry point into the housing. So you just mount the fan to their bracket.
However, per IRC and ANSI/AARST, sidewall exiting of radon systems is not allowed, and the fan may not be installed in a conditioned space, it must be installed in the attic, garage, or exterior. Just because a product is made and sold at a big box store does not make it correct.
Passive radon systems (no fan) must exit through the roof, and there could be a very small chance your AHJ may have a variance for active (fan) radon systems discharging through the wall, so you should check with them.
3onthetree is offline   Reply With Quote
