Thermostat Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 09-08-2020, 07:22 PM   #1
Thermostat heat pump
My new Emerson thermostat has a setting for cooling cycles.short med and long. How is this accomplish ed
Coach44 is offline   Reply With Quote
Old 09-08-2020, 07:26 PM   #2
user_12345a's Avatar
Rewards Points: 92
Re: Thermostat heat pump
Some stats cycle based on swing, so if you have a setting of 70, on a 71 and off at 69.
Better ones use an algorithm and monitor rate of temperature change and the setting determines target cycles per hour - they don't just use swing.
Don't know about emerson - probably fixed swing.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old 09-08-2020, 07:29 PM   #3
emerson 1f83h-21np
Old 09-08-2020, 08:27 PM   #4
Rewards Points: 92
Manual says heat cycle rate, slow, medium, fast with no explanation. I don't know what to tell you - you would call have contact emerson support or something to find out.
