System Sizing - HVAC - Page 6 - DIY Chatroom Home Improvement Forum
Like Tree5Likes
Old 01-07-2018, 09:01 AM   #76
Rewards Points: 200
Re: System Sizing
[QUOTE=user_12345a;5014114]At 78 it's almost not worth turning on at all.
Overall, it sounds like heating is more of a priority than cooling.
What kind of backup heat do you have? is it a dual fuel or propane/oil or do you have an air handler heat strips?
QUOTE]
Air handler heat strips are used for backup plus I have a pellet stove to take the edge off if it gets too cold.
AC is used in those high humidity times and the temps reach the 90's. If the wife complains I might set it lower in the evenings when sleeping.
shocker is offline   Reply With Quote
Old 01-07-2018, 10:42 AM   #77
Rewards Points: 1,082
Re: System Sizing
i would go 3 ton 2-stage for the extra heating capacity.
Unless you can switch to gas if u have it, then you can size for ac only with no operating cost increase.
WARNING: I am not in the business of any trade or topic I give advise on. Follow advice at your own risk. I have previous diy experience plus good knowledge of theory.
user_12345a is offline   Reply With Quote
Old 01-07-2018, 11:49 AM   #78
Rewards Points: 200
Re: System Sizing
No access to natural gas. I appreciate everyone's input but as you can see there are several opinions out there. I've had several estimates but none of the big companies around here did a load calc and just recommended replacing the current system with 3 tons. Thanks again!
Old 01-07-2018, 12:24 PM   #79
Re: System Sizing
Well, the consensus except for one is not to upsize.
The load calc is supposed to tell you what to put in, but with heating, if you downsize it means higher bills due to heat strip use.
Going 2-stage so you're not 40 to 50% oversized for cooling is worth looking into, more money to purchase and repair though.
How to convert existing R22 system to R410A pointedspider HVAC 39 03-25-2017 08:32 AM
Help make less confussing grounding electrode and equipment grounding? jackmel Electrical 1 01-14-2014 09:50 AM
A strange one - polybutelene piping used in radiant heating system GordCooper Plumbing 4 03-13-2012 10:09 PM
Need Help Buying a Sediment and Water Softener System. vpr80 Plumbing 10 02-23-2012 10:26 AM
New Heating & AC system takes long time to warm up home poston8 HVAC 10 11-10-2010 03:26 PM
