System Sizing - HVAC - Page 5 - DIY Chatroom Home Improvement Forum
Like Tree5Likes
Old 01-06-2018, 04:21 PM   #61
Rewards Points: 2
I am going to assume the Op may be a bit confused by now...Earlier in this thread it was a majority vote it seemed that a 4 ton was way way over kill and was Not Recommended by no means and now since the contactor that has suggested this from their software it Could Now be acceptable...I am confused myself whats changed here...maybe im missing something..I hope I don't seem rude asking..
Mikel7829 is offline   Reply With Quote
Old 01-06-2018, 04:30 PM   #62
Rewards Points: 1,112
Re: System Sizing
Don't know, i've always thought 4 ton was overkill and listed the reasons why it's a bad idea.
New information though is that it's a heatpump application.
In that case sizing is a balancing act, the higher capacity can help reduce the use of very expensive backup heat.
So if the air ducts are okay for 3 tons, it may make sense to get a 3 ton 2-stage.
The op could drop from a 3 ton to a 2 ton hp and have the heating bills skyrocket despite getting a more efficient machine because of all the extra resistance heat needed to maintain the setting.
WARNING: I am not in the business of any trade or topic I give advise on. Follow advice at your own risk. I have previous diy experience plus good knowledge of theory.
user_12345a is online now   Reply With Quote
Old 01-06-2018, 04:44 PM   #63
Rewards Points: 70
Re: System Sizing
It happens. Sometimes we get carried away. However in this case, we are talking about a few completely different cases.
1) AC only. 2-2.5 ton was suggested.
2) standard heat pump. 2-3 ton, depending on backup heat
3) inverter heat pump. They work better when oversized compared to single speed units. They handle the balancing act better. User is right that the ductwork would likely need modification for optimal performance. They are expensive to buy and repair, but do save a bit in electricity.
Cheers!
supers05 is offline   Reply With Quote
Old 01-06-2018, 04:50 PM   #64
Rewards Points: 2
Actually I believe I suggested a 4.5 to 5 ton for this off the top of my head.. I gave a little wiggle room for possible future upgrades..lol..I did suggest in that as well that a proper sizing calculation needed to be preformed..If it was me and I was not in the business of HVAC ...I would get a couple more contractors to come out and make a bid then compare and go with the most sensible one..It is harder for us online to suggest then someone there in person looking at the project first hand..imo anyway
Old 01-06-2018, 05:13 PM   #65
Rewards Points: 70
Re: System Sizing
I do believe a 4.5-5 ton would be too big. The 4 is stretching it as it was, and that's too maintain heat during cold spells.
Yes, a seasoned pro will be able to run a load calc with more accuracy then a DIY'r. However, most won't do a calc, either because they charge more for that, or simple don't want to.
Don't forget that this is a DIY site, and there's been a few on here that have installed their own systems. For better or for worse. There's a few DIY'rs on here that do better then 4th year apprentices. Some people just need a little guidance and they do well. Others need to call a Pro.
Cheers!
Old 01-06-2018, 05:44 PM   #66
Rewards Points: 2
Cheers!
Is the one that suggested to him a 4th year apprentice?
Old 01-06-2018, 05:52 PM   #67
Re: System Sizing
There are probably some DIY'ers that can do better than the bottom 40% of trades people out there who completed apprentiships. Especially on proper sizing and commissioning, evaluating air ducts.
Experience alone is no indicator in itself.
Old 01-06-2018, 05:57 PM   #68
Rewards Points: 2
Oh I agree...schooling mean zip in some cases ...Common seanse trumps 10 fold....
Old 01-06-2018, 07:34 PM   #69
An old Tradesmen
Rewards Points: 7,444
Re: System Sizing
Originally Posted by shocker View Post
I do have issues with noise out of the closest supply vent which makes me alter the damper. We actually don't use AC that much in the summer since we live in the woods and have substantial shade. On the hot/humid summer days when we run it we usually set it to 78. We use ceiling fans all the time instead. Thanks again for everyone's insight.
Thats why you probably don't have severe humidity problems in the summer.
A 4 ton unit will be twice as loud at those registers as you have now. Plus be loud at more registers.
supers05 likes this.
Old 01-06-2018, 08:08 PM   #70
Rewards Points: 2
Its fairly simple to slow down the airflow to reduce un-wanted noise level..I believe you are aware of that..In my opinion I will stand behind my first recommendation around 4.5 tons..4 would be fine..Like stated I have wiggle room I know in this feild we all do different things..different ways..ect Its just the way it is..everyone theories are different on what works the best so on and so on..I am not singling anyone out but most of us don't want to be wrong..I am guilty of it myself but thats how it goes I guess...I notice everyone seems to go against others right or wrong..I dont know maybe its me maybe im reading to much into it..But there is no way I would put anything less then a 3.5 ton in the op's said house..period ..I do apologize if I made anyone mad in this thread...was not my intension
Old 01-06-2018, 08:22 PM   #71
An old Tradesmen
Re: System Sizing
You slow down a 4 ton heat pump units air flow to that of a 3 ton. You get high pressure lock outs in the milder temps of spring and fall.
The OP already has an over sized unit, on under sized duct work, so air flow with a 4 ton without duct modifications would probably be reduced to less then 1200 CFM. And he would end up with a conversation piece. Instead of a reliable heat pump system.
user_12345a and supers05 like this.
Old 01-06-2018, 08:24 PM   #72
Re: System Sizing
At 78 it's almost not worth turning on at all.
Overall, it sounds like heating is more of a priority than cooling.
What kind of backup heat do you have? is it a dual fuel or propane/oil or do you have an air handler heat strips?
Whether to stay with 3 ton may depend on if it's an all electric system or not. The oversizing for cooling is justified if it means using less strip heat.
I most certainly would not go for 4 ton, that may be the appropriate size for this house in a brutal climate with air ducts in an attic. I think you can slow the fan down to only 1350 to 1400 cfm without running into issues.
Old 01-06-2018, 08:33 PM   #73
Rewards Points: 2
. Like I said mod the duct work a bit would be fairly easy for the upgrade..I didn't say just install using existing duct the way it is..
Old 01-06-2018, 08:42 PM   #74
Rewards Points: 2
Not sure if you understand my meaning of slow down..I am talking about upsizing the volume of the first several feet of supply then taper down to the existing size of the supply...Then of course open up the volume of the return how needed..See what Im saying?
Old 01-06-2018, 09:45 PM   #75
An old Tradesmen
Re: System Sizing
You increase unit size by 1 ton, which in this case, is a 33% increase. You need to do a lot more then just increase trunk size for a few feet, and add a little more return.
Would need to add more supplies, which means increasing the size of the entire supply trunk. And add more returns from the house.
How to convert existing R22 system to R410A pointedspider HVAC 39 03-25-2017 08:32 AM
Help make less confussing grounding electrode and equipment grounding? jackmel Electrical 1 01-14-2014 09:50 AM
A strange one - polybutelene piping used in radiant heating system GordCooper Plumbing 4 03-13-2012 10:09 PM
Need Help Buying a Sediment and Water Softener System. vpr80 Plumbing 10 02-23-2012 10:26 AM
New Heating & AC system takes long time to warm up home poston8 HVAC 10 11-10-2010 03:26 PM
