Swapping In A Different Condenser Coil - HVAC - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By roughneck
Old 04-21-2020, 10:43 AM   #1
Rewards Points: 14
Swapping in a different condenser coil
I want to use a mini split for mobil use but the condenser unit is too tall for my application so I'd like to swap in a condenser coil / heat exchanger that's shorter in height (12-13 inches max). I found a few condenser heat exchangers made for large trucks that might fit the bill but these heat exchangers run R-134 instead of R410. Do you guys see any issues with doing this swap? Does the heat exchanger's "tube" size/shape matter between the two refrigerants? By "tube" I mean the individual lines that runs from one side of the heat exchanger to the other -- and has air turbulators/fins in between. Here is one example of a truck heat exchanger I'm looking at, it's for a Western Star truck: https://imgur.com/a/V5V6Odm
DeskDrawer is offline   Reply With Quote
Old 04-21-2020, 11:30 AM   #2
user_12345a's Avatar
Rewards Points: 38
Re: Swapping in a different condenser coil
mini-splits are well engineered, very sensitive and the components must all match - it's not a realistic option.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old 04-21-2020, 12:28 PM   #3
Rewards Points: 716
No, this will not turn into a workable option.
Not to mention R-134A runs a fraction of the pressure R-410A does.
The compressor and electronics are all in the outdoor unit cabinet. What would you do with them?
user_12345a likes this.
roughneck is online now   Reply With Quote
