Some Vents Blow Cooler Air Than Others - HVAC - DIY Chatroom Home Improvement Forum
Old 11-13-2014, 10:17 PM   #1
Rewards Points: 81
Some vents blow cooler air than others
My furnace blows up to tubes that immediately split left and right as seen here:
The route to the left goes the length of the house, and T's off perpendicularly a a few times, leading to a handful of vents across the house.
The route to the right just leads to two vents, and both are much shorter runs than those that went off to the left. It splits right away into the two directions:
These go no more than 10 feet, and each lead to just one vent.
The problem is that these latter two vents don't blow as hot as all the others (the ones from the left route described above). They seem to blow equally as hard, or very close to it anyway. It's just that they are warm as opposed to pretty hot like the others. It's 30 degrees out now so it's easy to tell that those two rooms are much cooler than the rest of the house.
I've found the damper in each of the runs in question, and confirmed that they are wide open. I've also run my hands all along both these runs in question about 20 times, and can't find any obvious leaks.
Any other ideas as to what could be causing this? I'm at a loss at these point.
Thanks!
99miles is offline   Reply With Quote
Old 11-14-2014, 09:18 AM   #2
Rewards Points: 1,192
Do these rooms have return air vents? If not try leaving the doors open a little.
bobelectric is offline   Reply With Quote
Old 11-14-2014, 09:51 AM   #3
Rewards Points: 81
No, neither have return vents.
One room is the kitchen which doesn't have a door (just an open doorway), and the door to the other room is always open.
Old 11-14-2014, 11:46 AM   #4
Rewards Points: 1,602
Is everything made out of the same material and insulated the same? Do the cooler vents have ducting that runs through a colder area like above a garage?
I can't see your pics since I'm at work so maybe my questions are easily answered by looking at the pics.
mikegp is offline   Reply With Quote
Old 11-14-2014, 04:31 PM   #5
Rewards Points: 81
Yes, they are all the same material.
No, they all run through the same area (exposed basement ceiling).
Tags
heater , hvac , vents
Have Gable/Soffit Vents Contractor Suggest Ridge Vents sallygump50 Roofing/Siding 3 05-11-2012 10:56 AM
Ridge vents, soffit vents, end gable vent confusion. joemill Roofing/Siding 4 04-01-2012 05:18 PM
Should I add 2 rotary turbine vents to roof to reduce summer heat? pcumming Roofing/Siding 3 09-30-2011 08:26 AM
Ridge vents and roof vents jerry1967 Roofing/Siding 4 06-07-2010 05:40 PM
blow power of vents mcvane HVAC 5 08-11-2007 03:28 PM
