So, I Am Thinking About Replacing My Furnace, Myself. - HVAC - Page 4 - DIY Chatroom Home Improvement Forum
Like Tree14Likes
Old 07-31-2020, 10:10 PM   #46
Rewards Points: 716
Re: so, i am thinking about replacing my furnace, myself.
Originally Posted by user_12345a View Post
There's a lot of misinformation with respect to fracking
Apparently so.
HotRodx10 is offline   Reply With Quote
Old 08-01-2020, 07:25 AM   #47
raylo32's Avatar
Rewards Points: 2,174
I self installed one of these about... I don't know, 8 years ago? I got mine at Northern Tool but it seems they don't carry them anymore. But Home Depot does. These are Winchester brand which is just rebranded York/Johnson Controls. They carry mid and high efficiency units in all the common sizes in both single speed and 2-stage. These are really good quality, IMO.
This is an 80k 17" wide unit and as my original furnace was also 17" I already had a transition to mate up to the 20" wide plenum. As noted above these new furnaces are shorter. I went to a local sheet metal shop and had a simple rectangular transition to fill that extra gap.
IMO it is worth the extra cost to do a high efficiency unit and also to do a 2 stage. Much more comfortable that way. Just make sure to fully understand and follow the venting code. I also installed a condensate drain in the air intake pipe (you can install these furnaces 1-pipe and get intake air inside or 2-pipe and get intake air outside). Not sure it was necessary and I have never seen any water in it, but the manual called for it so I put one in. It really was trivial to connect that up to the normal furnace condensate drain that I plumbed to the existing air conditioning condensate drain, which was also trivial.
If you do this project, listen to BeenThere, Yuri, and others. They can help a lot.
https://www.homedepot.com/p/Winchest...MP12/313931468
Fix'n it likes this.
Live long and prosper.
raylo32 is offline   Reply With Quote
The Following User Says Thank You to raylo32 For This Useful Post:
Fix'n it (08-01-2020)
Old 08-01-2020, 07:46 AM   #48
Rewards Points: 154
thanx raylo. but a high efficiency, especially at that price, is just out of the question.
first, the cost, and then the roi = 30 years to break even ? i would be surprised if i am in this house 5 years from now, for various reasons. in fact, i have started purging some possessions for the anticipated move .
Fix'n it is offline   Reply With Quote
Old 08-01-2020, 07:48 AM   #49
raylo32's Avatar
They also have mid efficiency single speed units.
Old 08-01-2020, 07:56 AM   #50
Rewards Points: 154
thank you. i just looked, even a 80% is $1000. if that was all i could get, i would just order replacement parts for mine to have on hand.
