Size Of Unit(s) - HVAC - DIY Chatroom Home Improvement Forum
Old 06-25-2020, 08:08 PM   #1
Rewards Points: 6
size of unit(s)
I'm building a 20,288 sf private house. The house is 2.5 stories. It's a private frame and brick residence located in Nassau County, Long Island. How many central air conditioners should I install and how many tons should they be?
saltydo is offline   Reply With Quote
Old 06-25-2020, 08:25 PM   #2
Rewards Points: 740
Re: size of unit(s)
You’ll need a manual J to determine the answer to your sizing question.
roughneck is online now   Reply With Quote
Old 06-25-2020, 08:35 PM   #3
user_12345a's Avatar
Rewards Points: 86
Re: size of unit(s)
If you can afford to build a 20k sq ft house surely you can afford an engineer to properly design the distribution system and select the right equipment for the job.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old 06-25-2020, 08:43 PM   #4
Rewards Points: 914
Re: size of unit(s)
Agree with both Roughneck and user12345a. Best to have the engineer coordinate with your architect too, so that you don't have any "architectural surprises".
57TinkerMan is offline   Reply With Quote
Old 06-26-2020, 05:16 AM   #5
An old Tradesmen
Rewards Points: 116
Re: size of unit(s)
How many would depend on the layout of the house.
What size would depend on how much heat gain the house has.
An engineer or architect should be able to determine all of this for you for a fee.
Old 06-26-2020, 08:45 AM   #6
Rewards Points: 6
Re: size of unit(s)
The architect reccomends 5 compressors. Three 1.5 tons. One 3 ton unit. One 4 ton unit. This seems like overkill to me.
Old 06-26-2020, 08:54 AM   #7
Rewards Points: 86
Re: size of unit(s)
Was a load calculation done?
Old 06-26-2020, 09:41 AM   #8
An old Tradesmen
Rewards Points: 116
Re: size of unit(s)
Less than 1 ton per 1700 sq ft.
Doesn’t sound like he is getting carried away.
Old 06-26-2020, 04:32 PM   #9
sktn77a's Avatar
Rewards Points: 1,024
Re: size of unit(s)
Just don't leave this up to the builder or HVAC sub. Get a qualified architect and/or engineer to design the system.
sktn77a is offline   Reply With Quote
Old 06-26-2020, 08:52 PM   #10
Missouri Bound's Avatar
Rewards Points: 4,226
Re: size of unit(s)
Seems like a funny question for a DIY chatroom.
Do you want it your way or the right way?
Old 06-29-2020, 08:08 AM   #11
Rewards Points: 6
Re: size of unit(s)
Would the manual j show the total tons needed or the number of actual compressors needed?
Old 06-29-2020, 08:34 AM   #12
Rewards Points: 766
Re: size of unit(s)
The Manual J calculation method is a way to determine heat gains for a zone or a whole house. Figuring out the most efficient and economical way to set up the zones is a job for the pro who designs the system. That must be done before the Manual J cooling load calculations. For a house this size, it will pay to get someone who is very experienced to design the system. What you spend getting a good design will more than pay for itself in what is saved in installation and operating costs. Once the design and layout is done, then the Manual J calculations will determine the necessary sizes for units in each zone.
HotRodx10 is online now   Reply With Quote
The Following User Says Thank You to HotRodx10 For This Useful Post:
saltydo (06-29-2020)
