Return Size - HVAC - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By sktn77a
Old 03-30-2020, 02:56 PM   #1
Rewards Points: 22
Return size
Hi. I recently bought a house built in the late 60s. The return filter size is 15 x 30 5/8 x 1. Is there a way to retrofit the opening to take a more currently available filter size? I have found this filter size online, but they are mostly junk filters, or the better ones are much more expensive than normal. Thanks
musicbc is offline   Reply With Quote
Old 03-30-2020, 03:32 PM   #2
Rewards Points: 740
Re: Return size
Yes, but most return air filter slots are field produced and installed.
Something could be made to work.
What do you consider a “better filter”?
roughneck is online now   Reply With Quote
Old 03-30-2020, 04:05 PM   #3
Rewards Points: 22
Re: Return size
For example, I've found Merv 8 filters 12-pack for over $100, while other sizes on Amazon same count and quality are $60 or less. And the only way to get that quality and somewhat decent price is to buy a 12-pack or more. The AC is dated 2006, so it could go anytime (in AZ on the roof), so maybe I will get it changed then.
Old 03-30-2020, 05:28 PM   #4
Rewards Points: 376
Re: Return size
What are you considering junk filters? Mine are considered junk and our central heat/air system is 37 years old with a blower wheel that's never been cleaned and doesn't need cleaning.
Old 03-30-2020, 08:45 PM   #5
Re: Return size
Filters should be changed twice a year at a minimum preferably before each season summer/winter. Depends on how much you use the system and pets
Sent from my SM-G950U using Tapatalk
Matt1019 is offline   Reply With Quote
Old 04-02-2020, 07:36 PM   #6
sktn77a's Avatar
Rewards Points: 1,024
Re: Return size
Originally Posted by Matt1019 View Post
Filters should be changed twice a year at a minimum preferably before each season summer/winter. Depends on how much you use the system and pets.
You may get by with a 6 month interval with a 4" pleated media filter in a clean home but the regular 1" filters will likely need changing every month.
Matt1019 likes this.
sktn77a is offline   Reply With Quote
