Results 1 To 5 Of 5 Thread: Carrier 58PAV - Error Code 14 - Ignition Lockout - HVAC - DIY Chatroom Home Improvement Forum
Old 05-04-2020, 06:22 PM   #1
Rewards Points: 6
Results 1 to 5 of 5 Thread: Carrier 58PAV - Error Code 14 - Ignition Lockout
Carrier 58PAV, approximately 20 years old. I've previously replaced the igniter, and the fan motor.
Problem: Igniter glows, gas flows, burners ignite, and the gas shuts off a few moments later. I've handled this before by cleaning the flame sensor, however this time it's different. I put a multimeter between the flame sensor, and the board, and did not detect any micro-amperage. The sensor didn't appear broken, and was able to complete a simple circuit, but I replaced it anyway. Same error after replacing the flame sensor.
Nothing has changed with wiring, no maintenance to the furnace in over a year. The ground connection is tight on the burner and gas. The flame sensor wire is connected correctly. I disconnected and reconnected the wire harness to see if it was loose or corroded, but everything looks ok.
What else can I test?
Is circuit board replacement my next action?
Chuck83 is offline   Reply With Quote
Old 05-04-2020, 06:36 PM   #2
user_12345a's Avatar
Rewards Points: 52
Re: Results 1 to 5 of 5 Thread: Carrier 58PAV - Error Code 14 - Ignition Lockout
shut the gas and after the igniter glows, check ac voltage between flame sensor and ground. (modern boards do check for flame all the time, unsure of yours.
Could be a dirty burner and or plate at heat exchanger inlets.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
Old 05-05-2020, 07:54 AM   #3
Rewards Points: 6
Trying to figure out how to measure ac voltage between flame sensor connector and ground...
Dirty burner or heat exchanger could cause the ignition lockout? Even if all the burners ignited?
Old 05-05-2020, 01:06 PM   #4
Rewards Points: 6
Nevermind, $38 used board on ebay, and everything works again!
Old 05-05-2020, 01:24 PM   #5
Rewards Points: 52
Has to do with how it proves flame - power goes through the flame, usually to the burner.
