Replacement AC Choice - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree2Likes
Old 06-03-2020, 07:14 PM   #16
user_12345a's Avatar
Rewards Points: 38
Re: Replacement AC Choice
check schematic to know which color is start winding of motor and goes to the F terminal on the capacitor.
the other from the fan on the same circuit connects to the common terminal.
the cap should have terminals labelled F and H. C/common may not be labelled.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old 06-03-2020, 07:42 PM   #17
Rewards Points: 68
Okay, I see by looking at the schematic where it goes, but, do I need to be concerned about fidgeting around with the capacitor? I've repaired the wire and put on a new connector, just need to plug it in, but capacitors make me a bit nervous.
Charles218 is offline   Reply With Quote
Old 06-03-2020, 08:00 PM   #18
Rewards Points: 38
Make sure the capacitor is discharged.
If you want to do things properly, put a bleed resistor across the terminals for 30 seconds, hold with insulated pliers.
https://www.amazon.com/93106-QC-13-B.../dp/B07JMFB4L6
If you want to just be quick, short the terminals with a screw-driver you don't care about, short the terminals. if it's charged there will be a spark and loud pop.
Being cheap, i would go for the latter, most do.
Old 06-04-2020, 08:35 PM   #19
Rewards Points: 68
Things are "cool" again, replaced the damaged wire, that didn't do the trick. Replaced the capacitor and all is back in full operating condition. Thanks to all for your generous assistance with this.
user_12345a likes this.
