Replace Capacitor And Contactor? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-08-2020, 11:21 AM   #1
Rewards Points: 412
Replace capacitor and contactor?
It has been in the 90s for a week or two and looks like another week to go at least.
Our conventional (gas heat; a/c) York system is going on 11 years this December and I'm thinking it may soon be due for something to go wrong on one of these hot/humid days. I'm thinking to replace the cap and contactor as they are most likely bits to fail.
Any thoughts?
If yes, suggested sources on-line?
bob22 is offline   Reply With Quote
Old 07-08-2020, 12:23 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 162
Re: Replace capacitor and contactor?
Contactors very rarely fail but if you want to get a spare then go ahead. They are not very expensive. Capacitors do fail and it is a good idea to have a spare.
supplyhouse.com is good.
https://www.supplyhouse.com/
You need to know the rating of the contactor in amps plus get the specs off the capacitor as they are rated in various sizes in microfarads. Anywhere from 15-45 mfd and there is a VAC rating also.
That should be on the capacitor and the contactor I would just buy a 30 amp one even if you have a 20 amp as the 30 is heavier duty and almost the same price.
If you have a 4 or 5 ton AC you may need a larger than 30 amp contactor so try get the specs off it.
Old 07-08-2020, 12:48 PM   #3
user_12345a's Avatar
Rewards Points: 40
no need to replace stuff that's still good, but go ahead and stock inexpensive parts.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
Old 07-08-2020, 02:17 PM   #4
Rewards Points: 412
Manual indicates it (ycjf 42s41s1a) needs a 45/5 MFD Round Run Capacitor (440V), part #: S1-024-25120-700.
Prices are all over the place on these: $29 to $42 from HVAC houses, but most are out of stock.
Amazon goes from $9.50 to $22. Is ClimaTek, Packard, or Genteq any good? One better than another?
I appreciate the help!
Old 07-08-2020, 02:44 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 162
Genteq is made by GE and they make high quality ECM motors so I would buy that one.
The rest are cheap asian ones and don't last as long.
The Following User Says Thank You to yuri For This Useful Post:
bob22 (07-08-2020)
Old 07-08-2020, 02:56 PM   #6
surferdude2's Avatar
Rewards Points: 896
I also recommend Genteq. Made in America.
Get It Here
Ah, but I was so much older then...I'm younger than that now
surferdude2 is offline   Reply With Quote
The Following User Says Thank You to surferdude2 For This Useful Post:
bob22 (07-08-2020)
