Reason For Cold Room? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-29-2020, 07:02 PM   #1
Rewards Points: 22
Reason for cold room?
We moved into a new home about 2 years ago in MN. As it turns out, my youngest daughter's room is always cold. It's the SW corner of the home. As I'm working in the HVAC while finishing the basement, I noticed it may be done incorrectly, or better yet, could have been done better. It looks like they put the run in right off of a 90. It's the first run in the house off the furnace so it's always boggled my mind even more. While I'm doing the basement duct work, is there a way I could improve the heat to that room?
EGrant23 is offline   Reply With Quote
Old 03-29-2020, 07:11 PM   #2
Rewards Points: 732
Re: Reason for cold room?
It’s either due to an unbalanced system, poor duct design or a damper stuck shut.
How big is this duct? Is there a return duct in the room?
roughneck is online now   Reply With Quote
Old 03-29-2020, 07:30 PM   #3
Rewards Points: 22
Yes, there is a return in this room.
Reason for cold room?-1.jpg   Reason for cold room?-2.jpg   Reason for cold room?-3.jpg
Old 03-29-2020, 07:31 PM   #4
Rewards Points: 166
Tell us more about the house and the location of this cold room. How many windows, how many exterior walls, and what is under it. Do you have attic access to inspect insulation and/or ducts up there?
Bud
You beat me by 1 minute
Can you explain what we are seeing in the last pictures?
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Old 03-29-2020, 07:35 PM   #5
Rewards Points: 166
I little rotate and they look a lot better. Happens all the time.
Bud
Old 03-29-2020, 07:50 PM   #6
Rewards Points: 22
Bud
Thanks Bud. It's a 2 level split story home. The bedroom in question is in the SW corner of the home with two exterior walls. There is a single window in he room. It's an entire unfinished basement below. All the attic insulation looks good and there is no duct work up there. The pictures (crappy I know) show the run from the main trunk in the basement to that bedroom. That run is 6' to the supply vent in the floor to that room (roughly 20' from furnace). There is no other heating/cooling issues in the home. I just thought the way that duct twists from the 90' of the main trunk may not be getting a lot of air flow. Other than that, I'm not quite sure what the issue would be.
Old 03-29-2020, 08:07 PM   #7
Rewards Points: 166
I'm a retired energy auditor, now energy consultant so in addition to the delivery system I look at the heat loss.
In winter air infiltration enters the low leak areas (often where the house rests on the foundation) then finds its way up through the house. The amount of infiltration is often shocking and basements that feel ok are actually dealing with a lot of cold air. During a cold spell you can often feel the cold air leaking in.
in any case, aggressive caulking where the house rests on the foundation is always beneficial.
I'm not hvac but I like to measure the supply air temp leaving the furnace and then arriving at the supply register. Also compare that temp to the return air temp.
Does the volume of air reaching that room seem equal to other rooms?
Did you mention if there is a return register in that room?
Bud
Old 03-29-2020, 08:51 PM   #8
Rewards Points: 22
There is a return from that bedroom. The volume of air reaching that supply from the bedroom does feel equivalent to the others. 1/2 of the basement is below grade. I spent a lot of time in the basement this winter framing and doing some other things to finish the basement. On several occasions, I inspected around the four basement windows, and other areas to see if I could feel any cold air leakage, and I didn't come across anything - a few of these occasions we are talking -20 outside. We are probably talking a significant 8-10 degree difference between that room and the two on either side of it (one only has one exterior wall, and the other has one exterior wall + garage). No other cool spots in the home.
Old 03-29-2020, 09:14 PM   #9
Rewards Points: 166
Measure the temperature of air as it leaves the furnace and then as it is delivered into the room. Does that duct pass through any outside walls?
As a note, the rim joist where the floor joists connect to the perimeter is just 1.5" of wood. That puts it in the category of a single piece of glass and we all know how terrible single pane windows are. Is there currently any insulation in that joist cavity?
SW corner receives the most sun so is not like a northern exposure.
Now, I cheat but it works like magic, I use an infrared camera. Modern cameras can be rented or even low cost versions purchased and they would give you a good look at where the cold spots are. Just an option.
Bud
Old 03-30-2020, 06:46 PM   #10
Rewards Points: 22
An update, I kicked on the furnace today. The airflow to this bedroom is drastically lower than the neighboring bedrooms. I've attached two more pics of the way the ducts are ran in the basement.
1) This is the run from the main trunk to the upstairs bedroom (roughly 6'). You can see the two 90's used off of the 90 in the main trunk. The furnace is roughly 10' behind me in this picture.
2) Once again, able to see the twists coming off the main trunk with the furnace in the background. I am wondering if this run is too close to the 90 and would better be suited moved over to the left a foot or so.
Thoughts?!
Old 03-30-2020, 07:51 PM   #11
Rewards Points: 166
New home, what has the builder or hvac guy said about the minimal air flow?
Some of the hvac pros will have to comment on a fix, I'm not hvac.
Bud
Old 03-30-2020, 07:58 PM   #12
Rewards Points: 11,450
Amazon has some pretty cheap anemometers. Gives you airspeed and temperature. For these kind of prices, I am not sure how accurate they would be, but should be good for a quantitative comparison of your various rooms.
https://www.amazon.com/s?k=holdpeak+...b_sb_ss_i_1_15
SPS-1 is online now   Reply With Quote
