Radon Mitigation Install - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-16-2020, 08:36 AM   #16
When a radon mitigation system is installed and a suction test hole is drilled in concrete floor should the suction test hole be filled in after the radon mitigation system is installed. If it isn’t plugged or filled in does it pose a risk for unwanted water entry in the basement?
Popcburns is offline   Reply With Quote
Old 05-16-2020, 10:07 AM   #17
Hammered Thumb
Rewards Points: 80
Re: Radon mitigation install
Originally Posted by Popcburns View Post
When a radon mitigation system is installed and a suction test hole is drilled in concrete floor should the suction test hole be filled in after the radon mitigation system is installed. If it isnít plugged or filled in does it pose a risk for unwanted water entry in the basement?
Yes, all test holes and cracks/joints in the concrete to keep the pull of air coming from under the slab. If you have chance of water entry there are other problems to address.
3onthetree is offline   Reply With Quote
Old 05-17-2020, 05:27 AM   #18
Thanks - So did you say the suction test hole should be plugged or not?
Old 05-17-2020, 06:43 AM   #19
Rewards Points: 124
Good morning popc,
Yes he said fill all test holes. There should be a "u tube manometer" somewhere attached to the exhaust pipe that will indicate the desired level of negative pressure the system in creating. Too many holes in the slab defeats the fans ability to create that negative pressure.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is online now   Reply With Quote
New cabinets, subfloor & install height Ohming Building & Construction 10 03-02-2011 02:18 PM
Should I install interior doors before floor? pttcc Flooring 13 11-23-2010 09:02 AM
Radon mitigation during construction upinsmoke Building & Construction 5 05-01-2010 04:36 AM
Is This Bad Radon Mitigation? golddog Building & Construction 4 04-21-2010 02:56 PM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 08:49 PM
