Radon - HVAC - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 02-02-2020, 10:21 PM   #1
Rewards Points: 48
Radon
Not sure where to post this so you guys are the winners. I'm finishing my basement and there is a rough in down in the basement for Radon where the pipe leads down into the sump pit and it leads outside. I'm having work done on the concrete slab (long story) and they are moving that sump pit. The contrator said he'd install the radon fan if I provide it since he's moving the sump portion of the pipe. Anyone have experience in these that you could provide advice on what to buy? From what I've seen its literally just a fan that connects to the PVC
mpoland33 is offline   Reply With Quote
Old 02-03-2020, 04:37 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 392
Re: Radon
We installed this one: https://www.homedepot.com/p/RadonAwa...32-1/203746905 last week on a built in piping. Difference was, the piping was coming from the slab through a 6" exterior wall. We extended the pipe (4") to an elbow to exit the wall, then turned it vertical again into this fan. It is directly wired to a GFCI receptacle that is always on.
It mounts to the wall via spanners. It doesn't come with a method of preventing water intrusion, so installing some sort of screened pvc pipe loop on top would be good. I'm letting the GC figure that one out as he wanted to put a cheesy dryer vent on it.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 02-03-2020, 05:41 AM   #3
Rewards Points: 48
Re: Radon
Great, thanks for the response. Ours looks like its already directed outside but I need to figure out where it goes. For something that seems so important at home inspections, it sure is hard to find information on it
Old 02-03-2020, 06:48 AM   #4
Rewards Points: 246
Re: Radon
Has the radon level been tested? The level helps determine the fan size.
If you have high levels the sump pit may need to be covered to help seal the basement floor to allow the radon system to pull a negative pressure. On new homes they sometimes install the pipes "just in case" but have not tested. If they did test and the reading was bad I would expect the fan would have been installed.
As for relocating the pipe going into the pit, that isn't where a radon system connects. There should have been a layer of gravel plus a network of pipes under the entire slab. I don't think your contractor knows how a radon system works or its proper install.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is online now   Reply With Quote
Old 02-03-2020, 07:49 AM   #5
Rewards Points: 48
Re: Radon
Long story short, no it has not been tested but we have 6 neighbors on our little mountain, and they all have had high levels. I'm just assuming we do and since we are having the concrete work done, he is going to install the fan.
Long story long- we recently found out the builder (in 2003- 3rd owner here) did not connect a drain tile to the sump so the sump has just been sitting doing nothing (it was connected to an exterior pipe in the basement stairwell so it runs about once a month or so it seems). So they are going to dig up the perimeter of the concrete floor and install a french drain of sorts- though they call it something else. In doing so, they are moving the sump to a corner of the basement before adding 2 more pits. When they move it, the roughed in radon pipe will be void so he has to move the pipe (really just cut it and add it to the new pit). I found out this morning that the pipe does run all the way up to the roof and runs through the attic. Should I just install the fan up there? I see online that is an option.
Because the work is being done starting a week from today, I'm trying to learn as much as possible as quick as possible so that either he can install the fan onto the PVC in the basement or I'll install it in the attic later.
Old 02-03-2020, 07:51 AM   #6
Rewards Points: 48
Re: Radon
Bud, to your comment about where it connects, currently the radon PVC goes down into the sump pit but is just sitting down there in the pit. The sump lid was not sealed either which is going to be fixed with the new pit.
Old 02-03-2020, 08:11 AM   #7
Rewards Points: 246
Re: Radon
U-tube manometer and it indicates the negative pressure under the slab. The drain system they are installing cannot be open to the air or the radon abatement may be defeated. Inside French drains (or whatever they are calling it) that are intended to catch water in the basement don't sound compatible. Normally the slab is sealed to the wall and all penetrations like the sump pits are sealed.
However, sump pits also provide some protection from broken water pipes or other domestic sources of water and a sealed pit won't help. Strictly my opinion, once the typical sump pits are sealed one needs to add a pit (a big bucket) open to the basement to catch such leaks and discharge them to the outside. I've seen many washing machine hoses let go, bad solder connections, and burst pipes from being frozen.
Just an fyi and I'm not a radon pro, just a builder and energy professional.
Bud
Old 02-03-2020, 08:32 AM   #8
Rewards Points: 48
Re: Radon
Thanks so much for the info. He told me his system is radon compatible....but you bring up some great questions for me to ask.
With what they are doing...they are digging around the entire perimeter of the basement and putting gravel in, then a sloped PVC pipe leading to the sump pit. The PVC is then covered with gravel and then 4" of concrete is placed on top of that. After which eventually I'll finish the basement floor on top of that.
"The message I just got from the installer is:
It's radon sealed and ready in a sense that if you install a radon system, all they have to do is tap into the system without having to cut into the floor or into his system. "
Old 02-03-2020, 08:33 AM   #9
Rewards Points: 48
Re: Radon
oh I forgot to mention he will have to drill weep holes into the concrete walls to allow the water in to the drains that are in the basement
Old 02-03-2020, 10:00 AM   #10
Endless Projects
Rewards Points: 1,670
Re: Radon
You should really run a test before you try to solve this. You might be solving a problem that does not exist or not going far enough to mitigate if you have it really bad. You should know what your radon level is before you start. The steps you have to take depend on the level of your problem.
I tested 16 piC/l in my home and got it down to 5 by simply opening blocked vents in the crawl space. They are still covered by snow so think if I shoveled out the area around the outside the level should drop to an acceptable range under 4.
Here is a resource I have used to help me figure it out.
https://www.indoor-air-health-adviso...itigation.html
Photobug is offline   Reply With Quote
Old 02-03-2020, 10:23 AM   #11
Hammered Thumb
Rewards Points: 152
Re: Radon
The radon access point should not originate in a sump pit. It sounds like there is no underslab piping, just a pipe stuck into the old sump lid and they called it a "system." Not quite understanding, but you are getting 3(?) new pits for water, and the old pit will remain the radon point? Is this one point centrally located or able to pull from the entire basement? At the very least, the old pit tub should be removed, filled with gravel and continue the VB and the new pipe sealed off with concrete.
If you have no underslab piping, a full perimeter loop can be installed while they have the slab cut. This can be routed to your existing vertical exit, and remain as a passive system until you have the time to test your radon level. Then, a fan can be added in the attic and more access points if needed, based on the reading.
Personally, since you are doing so much work anyway, I would have excavated a hole outside to verify if they have a footing drain, and if so, then just tied it in rather than let the water inside the entire perimeter. If I found no exterior drain tile, I would have evaluated at that point which side to dig on is the better solution.
But to answer the main question, you do not need to give him a fan to connect it to anything in the basement. You just need to make sure that you provide the best way to pull underslab air while you have a chance now.
3onthetree is offline   Reply With Quote
Old 02-03-2020, 12:37 PM   #12
Rewards Points: 48
Re: Radon
I must not be explaining it well enough with my lack of knowledge and terminology. When they pull the 16" trench of slab up around the perimeter of the house, he is then creating a pathway that leads to the sump. This is sealed and from there the radon PVC is sealed into the lid/sump pit. It does just rest inside of it. According to an inspector I talked to, this is a well used practice for people who do not have drain tiles or if the drain tile has collapsed...and with my contractor's system being radon certified, he said it would just tie in to the under slab work he is doing. He also said I would only need one radon fan/pipe even though I would have 3 pits. Without the fan, it would just be a passive system.
Old 02-03-2020, 02:57 PM   #13
Hammered Thumb
Rewards Points: 152
Re: Radon
A radon "certified" contractor would not be asking you to give him a fan. And if he is removing/relocating/adding sump pits, he would not be utilizing a sump pit as a suction entry point, when core drilling holes (not to mention he has the concrete torn up) is easier. Sounds like marketing.
There are two "systems" which should be kept separate:
1. soil water drain system
2. radon mitigation system
Best practice is to not combine them. The old easy fix was add a pipe to the sump lid. That is not recommended now.
It still sounds like when he is going to dig up the perimeter, he is not going to install a standard 4" corrugated or solid pipe, but going to install some sort of prefab channel drain, like a "waterguard," is this correct? Radon-waterguard_1497879481.jpg
Then drilling holes at the bottom of the wall will allow the water from outside to enter the inside and work its way into this perimeter drain, which is carried to a sump pit. A second pit is used as an optional single pump backup, or if the water table is too high/too much SF to cover. A third pit, I don't know unless you have a basement layout with lots of doglegs. This type of channel might negate any radon system you have.
If your house was built in 2003, there should be gravel and a vapor barrier. The radon should pull air from this "air permeable" gravel layer. If you picture a sump crock, it basically would need 3" holes put in higher than a water pipe to pull from the gravel layer. You don't need the depth or necessarily a "collection bin." So pulling from a crock even dedicated to radon has no benefits except taking up floor space.
Since you are tearing up the concrete, you should install a separate radon pipe loop. This is your chance. Connect it to the vertical pipe, and it is a passive system. After some time passes, have a radon test performed. The amount present will determine if you change to an active system - by adding a fan (in-line radon, HRV/ERV, wall exhaust, etc of your choosing). But if the level is low, the passive system is adequate and no fan is needed. Here's the EPA website on radon EPA.gov/radon
Bud9051 likes this.
Old 02-04-2020, 05:48 AM   #14
Rewards Points: 48
Re: Radon
The guy I'm dealing with is a waterproofer. He does not install Radon mitigation. His system is what is radon certified in the sense that it can tie in when a radon mitigation system is installed. We were pitched on Waterguard and chose to go a different direction. It is called a sub floor pressure relief system. It IS 4" corregated PVC that is going in.
Because he doesnt install radon, I don't really know an option I have to make a loop. What kind of PVC would I use anyway? If I loop it around the basement, where would the ending be in the sense of, how does the radon get into the pipe...just leave it open on one end?
Old 02-04-2020, 05:51 AM   #15
Rewards Points: 48
Re: Radon
also, I do have a lot of doglegs in the basement.
If he is digging and installing gravel into the entire perimeter of the basement, can't I just connect that vertical pipe in the gravel he is putting in?
