Pulled Too Hard... What Am I Looking At? - HVAC - DIY Chatroom Home Improvement Forum
Like Tree2Likes
Old 03-05-2020, 09:58 PM   #1
Rewards Points: 6
Pulled too hard... what Am I looking at?
So Iím rewiring my thermostat and I pulled too hard on the wire in the wall... Iíve been under the house... please donít make me go back.
ItMightWork? is offline   Reply With Quote
Old 03-05-2020, 10:15 PM   #2
Rewards Points: 732
Re: Pulled too hard... what Am I looking at?
Shut off the equipment, your likely to short something with bare wire touching.
Do you have separate systems for heating and cooling? Why is there 2 bundles of conductors running to that one thermostat?
roughneck is online now   Reply With Quote
Old 03-05-2020, 10:21 PM   #3
Rewards Points: 6
Please don’t make me go back in the crawl space
So I was replacing a thermostat... very easy job... until I pulled too hard on the wire in the wall and pulled out a good length of it. I finished wiring in the thermostat and turn the power back on and the thermostat doesn’t work. I triple checked my wiring is right, but it’s not turning on. I went in the crawl space and found the wire but it was still secured to a support beam so it wasn’t unplugged... not sure what to do. The old thermostat doesn’t work now either. There seems to be an old hvac connection that was hidden in the wall? Or maybe it’s supposed to connect to this. Not sure?
Pulled too hard... what Am I looking at?-image_1583468364792.jpg   Pulled too hard... what Am I looking at?-image_1583468387194.jpg   Pulled too hard... what Am I looking at?-image_1583468434703.jpg
Old 03-05-2020, 10:33 PM   #4
Rewards Points: 6
It’s one system, I have no idea why there are two bundles. When the cord came out of the wall that came with it.
Old 03-05-2020, 10:40 PM   #5
Rewards Points: 2,304
Re: Please donít make me go back in the crawl space
It looks like you have an older 5-wire cable that may have been abandoned and replaced by the newer 6-wire (well, really 8-wire) cable that is connected to the thermostat.
Are you sure you found the other end of the correct cable when you were in the crawl space?
RAL238 is offline   Reply With Quote
Old 03-05-2020, 10:50 PM   #6
Rewards Points: 6
That seems to be the case.
Yes, they were together in the crawl space. Along with all of the spiders that ever existed.
Old 03-05-2020, 10:54 PM   #7
Rewards Points: 732
Was the second bundle landed on the thermostat or was it just sitting in the wall?
Is there a similar bundle at the equipment?
Old 03-05-2020, 10:57 PM   #8
Rewards Points: 6
I believe that was an old system that was abandoned?it was just in the wall. The 8 wire system is what’s wired to the thermostat
Old 03-05-2020, 10:58 PM   #9
Rewards Points: 732
Is that’s the case just leave it be.
Is the other end of the abandoned wire connected to anything?
Old 03-05-2020, 11:11 PM   #10
Rewards Points: 6
I couldn’t find the end of the 5 wire
Old 03-06-2020, 12:05 AM   #11
Mystriss's Avatar
Rewards Points: 7,354
Could maybe check the loose wire(s) for line/signal voltage to confirm it's not in use?
BoBBuild likes this.
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is offline   Reply With Quote
Old 03-06-2020, 03:40 AM   #12
Naildriver
chandler48's Avatar
Rewards Points: 330
Duplicate thread https://www.diychatroom.com/f18/plea...-space-681063/
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 03-06-2020, 03:41 AM   #13
Naildriver
chandler48's Avatar
Rewards Points: 330
Re: Please don’t make me go back in the crawl space
Duplicate thread https://www.diychatroom.com/f17/pull...ooking-681061/
Larry......
Old 03-06-2020, 06:56 AM   #14
Rewards Points: 6
New info. My water heater doesn’t work this morning.
Old 03-06-2020, 07:00 AM   #15
Rewards Points: 732
Probably an unrelated problem.
What kind of water heater?
