Propane Tank Coating - HVAC - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By bob22
Old 09-14-2020, 02:59 PM   #1
Rewards Points: 2
I plan to bury a Trinity 500 gallon propane tank. It has never been below ground, but have some scratches and rust on it. Can anyone suggest a coating to apply to the mentioned areas and how to prepare the same?
mjt69 is offline   Reply With Quote
Old 09-14-2020, 03:20 PM   #2
Rewards Points: 426
Re: Propane Tank Coating
I saw a This Old House or similar on this and I remember that you have to be careful about groundwater floating the tank out and breaking the lines, releasing the propane and maybe kaboom.
Just sayin.
bob22 is online now   Reply With Quote
Old 09-14-2020, 03:35 PM   #3
Rewards Points: 280
I see no difference of that and a underground pipe line. I suspect there is plenty of information on the web for pipe lines . Cathodic protection required for a propane tank? I have no clue. Butane tanks are more commonly buried so there may be more information on the buried subject.
Edit: Edit:
Old 09-14-2020, 03:57 PM   #4
Rewards Points: 426
Just sayin.
https://www.thisoldhouse.com/westerl...sterly-project
mjt69 likes this.
Old 09-14-2020, 05:24 PM   #5
Red Seal Electrician
Rewards Points: 506
If I wanted to get as long a life as possible from the tank... I would not bury it.
u2slow is offline   Reply With Quote
Old 09-14-2020, 09:01 PM   #6
surferdude2's Avatar
Rewards Points: 902
Check out Propane 101 for some good answers.
Ah, but I was so much older then...I'm younger than that now
surferdude2 is online now   Reply With Quote
Old 09-14-2020, 10:51 PM   #7
Rewards Points: 5,150
When I was an inspector if a tank was going in a place with high ground water or danger of flood, it had to be placed on a concrete slab and strapped down before it could be covered.
Old Thomas is online now   Reply With Quote
