Portable Air Conditioner Shutting Down Before Reaching Temperature - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree10Likes
Old 08-10-2020, 10:38 AM   #16
2dr
Rewards Points: 16
Re: Portable air conditioner shutting down before reaching temperature
Definitely something I will check! Thank you!
2dr is offline   Reply With Quote
Old 08-10-2020, 11:42 AM   #17
user_12345a's Avatar
Rewards Points: 42
Originally Posted by 2dr View Post
So our best bet to get closest to continuous operation would be to increase the temperature the unit is set to? It sounds like it's impossible to to get it to 100% continuous operation. But if there are little tweaks I can make to increase the time it is on, that would be ideal.
No, i never said that.
Increase it and it will run less - lower heat gain. But put it down to 17c and it may shut off to stop the evap from freezing due to low return temp.
At night you probably only need 1 to 2000 btu/hr removed to keep the room cool. Even a small unit will always cycle.
I don't know why you're after continuous operation in the first place. It's not realistic at all unless you get a small inverter mini-split with a very good turndown ratio. Lots of $$$.
de-nagorg likes this.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old 08-10-2020, 12:39 PM   #18
Rewards Points: 344
Simple, just open all your windows, let warm air comes in, then it will continue run and never reach the set temp and it will not freeze up.
de-nagorg and 2dr like this.
clocert is offline   Reply With Quote
Old 08-14-2020, 09:33 PM   #19
2dr
Rewards Points: 16
I think you might be kidding, but also, would that work? I'm sure it will hard on the compressor to run that long and hard and wear it out sooner, and would also cost more money in energy bills, but ...
I think our seal on the window broke off slightly on some really warm days, and it seemed to run all night. You just might me onto something.
Tags
air conditioning
