It Pays To Know Your Landlord... - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 08-30-2020, 07:57 AM   #16
An old Tradesmen
Rewards Points: 58
Re: It pays to know your landlord...
Originally Posted by user_12345a View Post
What about using hydronic coil heat exchangers for free cooling in winter? - air to air, water transfers the heat outside. reduce reliance on refrigeration without bringing in contaminates.
obviously straight air economizers are off the table.
i'm sure this could be done with far less energy but means spending more upfront.
Using hydronics for cooling in the winter would require glycol to be added to prevent pipe freezing and bursting in the winter. Which increases the size of the system required, as glycol lowers heat transfer.
It would also mean 2 different systems, one for summer cooling, and one for winter cooling. Unless the hydronics was incorporating WSHPs. Which of course is still a mechanical cooling system.
Old 08-30-2020, 10:00 AM   #17
user_12345a's Avatar
Rewards Points: 48
*hydronic coil in existing air handlers, not entirely separate.
i know it can also be done when a chiller is used - when it's cold enough outside have a direct heat exchanger instead of running the chiller.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old 08-30-2020, 10:17 AM   #18
An old Tradesmen
Rewards Points: 58
Which requires glycol in the system. Which requires the hydro coil in the air handler to be larger.
Old 09-02-2020, 01:22 PM   #19
Rewards Points: 894
Still working on the bid. Will have to go with rectangular duct instead of spiral due to some height constraints with the lighting. Pictures show what you can get for a lot of $$$$ if you are not careful. Sorry for the sideways view.
57TinkerMan is offline   Reply With Quote
Old 09-02-2020, 01:27 PM   #20
Rewards Points: 894
More pics. 6 to 8 weeks for unit delivery. Carrier model 48HQ, will mount on 18" curb, route copper condensate line straight into the building then trap it before going into a condensate pump. Condensate line will be heat traced and insulated.
Old 09-02-2020, 05:21 PM   #21
An old Tradesmen
Rewards Points: 58
That is some sorry workmenship from them.
Old 09-02-2020, 05:58 PM   #22
Rewards Points: 716
Is the foil taped cardboard supposed to be permanent?
roughneck is online now   Reply With Quote
Old 09-02-2020, 07:26 PM   #23
Rewards Points: 894
You know, as bad as the current workmanship is, I'm glad to see the owners in good spirits (grow operation?) and are able to laugh about it and want to do the job right. The cardboard will be removed, the hole size in the side of the building is thankfully too small to handle what's needed so a neat hole can be cut and the duct flashed in. The return will need a bit of work to adapt to the hole in the drywall. The unit will have to be shifted away from the building an additional 3' or so and installed on a curb. Funny, I kind of enjoy jobs like this, they have a little bit of flavor to them.
