Oops Carrier Mishap Help! - HVAC - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By 57TinkerMan
  • 2 Post By 57TinkerMan
Old 07-02-2020, 06:57 PM   #1
Rewards Points: 2
Angry
oops Carrier mishap Help!
Hi,
Gave a shot at replacing furnace blower fan. everything went well except one wire Black form transformer was not in my pictures and it is disconnected form control board.The furnace is Bryant plus 80 and the control board is carrier/bryant cepl 130437-01, I just need to know when to plug the black lead form the transformer into the control board.
revvluvv is offline   Reply With Quote
Old 07-02-2020, 07:53 PM   #2
user_12345a's Avatar
Rewards Points: 38
Re: oops Carrier mishap Help!
check the schematic, usually on the blower the panel side that faces in.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old 07-02-2020, 08:10 PM   #3
surferdude2's Avatar
Rewards Points: 896
Look at the screw terminal strip where the thermostat wire connects... then to the end where the control circuit fuse is located (right end)... just beyond that fuse, you will see two push on blade terminals... both of them should have wires on them. Those wires come from the 24 vac transformer. If one of them is now vacant, then voila!
They are labeled sec 1 and sec 2 just to be sure you're looking at the right place and I have told you properly..
Ah, but I was so much older then...I'm younger than that now
surferdude2 is offline   Reply With Quote
Old 07-02-2020, 08:20 PM   #4
Rewards Points: 894
I think he is working with the primary side of the transformer, is so, connect the black wire from the transformer to PR1 on the board.
surferdude2 likes this.
57TinkerMan is offline   Reply With Quote
Old 07-02-2020, 08:27 PM   #5
Rewards Points: 896
Now that you rubbed my nose in it, he did mention that it was a black wire.
Old 07-02-2020, 08:47 PM   #6
Rewards Points: 894
No worries, no nose rubbing here. I think I delete more replies before posting than I actually post, and remembering some of my past posts, I should have deleted more!
raylo32 and surferdude2 like this.
Tags
bryant control board , bryant transformer
