Old AC Condenser "clicks" But Isnt Turning On (pics) - HVAC - DIY Chatroom Home Improvement Forum
Old 04-24-2019, 04:00 PM   #1
Rewards Points: 140
Old AC condenser "clicks" but isnt turning on (pics)
I ran power to it. First time its had power in 2+ years. When I switch thermo to cool, I hear it make some sort of clicking noise outside. I check power and when I touch both black and reds my "120" & "240" both illuminate on my tester. No idea if thats relevant. Seems odd both light up. At the box my red & black are my current & white in neutral. I bought 10/3 on accident and installed a ground anyways and capped it in the j-box. The old line coming from the condenser had only a black, red & white. But maybe that it clicks is a decent sign for a 16yr old condenser that hasnt ran in 2-3 years.
friesbruh is offline   Reply With Quote
Old 04-24-2019, 04:55 PM   #2
Rewards Points: 1,080
Re: Old AC condenser "clicks" but isnt turning on (pics)
Any idea what that plastic sheathing is for ? You will need to have a voltmeter to troubleshoot this.
Wilbits is offline   Reply With Quote
Old 04-24-2019, 05:14 PM   #3
Rewards Points: 14
Looks like it got a little warm. Disconnect needs to be replaced at the least.
Sent from my SM-G960U using Tapatalk
spitz1234 is online now   Reply With Quote
Old 04-24-2019, 05:27 PM   #4
Rewards Points: 6,580
That disconnect is junk. Got way too hot at one time.
Need an actual meter to go through everything.
roughneck is online now   Reply With Quote
Old 04-24-2019, 07:18 PM   #5
Rewards Points: 186
"At the box my red & black are my current & white in neutral"
What the hell does this mean?
There should be no neutral feeding that thing. You should have a ground and 2 110V hots, which is another way to describe 230V.
This looks to be what you have here. The black and red wires go from the 2 pole breaker to the tops of those fuses, and the white and black wires go from the bottoms of the fuses to your air conditioner condensing unit. That white wire shouldn't be white because it's not a neutral, but whatever.
I don't know what kind of tester you have, but if you can test each wire to confirm voltage that would be a good thing. If the wires going to the top of the fuses have power going to them while the ones on the bottom of the fuses don't then you have a blown fuse.
When fuses blow there is usually a good reason. Please be careful. Besides your apparent lack of electrical understanding, that disconnect does look to be messed up. The potential to hurt yourself or create larger issues is there.
bfrabel is offline   Reply With Quote
Old 04-24-2019, 07:57 PM   #6
Rewards Points: 140
I do not.
Noted.
Noted.
You sound like a complete psycho. Input disregarded.
Old 04-24-2019, 08:03 PM   #7
Rewards Points: 14
The click you hear is most likely the low voltage energizing the contactor coil and pulling the contacts in. I assume you have the "pull" from the dissconnect.
Old 04-24-2019, 08:09 PM   #8
Rewards Points: 1,082
You need to see if the contactor is getting 240v +/- 30 with a multi-meter.
Basic multi-meters are pretty cheap and it's as important to have one as it is a screw-driver for this type of work. If you can afford though get a clamp style meter that can check capacitance and amp draw.
If the contactor isn't getting power, you have to work backwards to see where the power is being interrupted.
bfrabel's post has good info but he was rude.
The white isn't a neutral, you can't always go by colors. There is no neutral in straight 240v circuits.
Only 240v circuits serving stoves and sometimes driers have neutral to drive the 120v components. (for example, many electric stoves have a regular plug, oven light)
WARNING: I am not in the business of any trade or topic I give advise on. Follow advice at your own risk. I have previous diy experience plus good knowledge of theory.
user_12345a is offline   Reply With Quote
Old 04-24-2019, 08:10 PM   #9
Rewards Points: 186
What? Please let me know which parts of my post sound psycho to you.
I was trying to help. Everything I was trying to say was true.
Seriously, which parts do you have issues with?
By the way I want to add that as others have said, the clicking is probably the contactor pulling in. This contactor is powered by 24v coming from the thermostat wire. Even if you have the main power shut off to the condensing unit, the contactor can still pull in and out if it's getting power sent to it from the thermostat.
You'll probably want to disregard that psycho little tidbit too though.
Good luck.
Old 04-24-2019, 09:06 PM   #10
Rewards Points: 496
That disconnect box has to be replaced. That particular style, we replace those a lot. The plug canít even fit in there properly. Also fuse looks bad on the right. Spend a couple dollars more and you will save in the long run. I canít tell you how many of that type box we have replaced, but itís a lot of them.
BayouRunner is offline   Reply With Quote
Old 04-24-2019, 09:23 PM   #11
Rewards Points: 140
Trying to decipher.
Ill get a MM tomorrow and follow your steps.
Is this sufficient or just like the last one
https://www.homedepot.com/p/GE-30-Am...0RCP/100576894
Old 04-24-2019, 09:41 PM   #12
Rewards Points: 140
Trying to decipher.
Old 04-24-2019, 09:47 PM   #13
Rewards Points: 14
If you have 10gauge wire on a 30amp breaker a non fused disconnect will do.
Old 04-25-2019, 09:31 AM   #14
Rewards Points: 496
The one you posted is low quality like the other. Look further
Condenser Fan On, Air Handler Blower On, Zero air from supply vents. Any ideas? jrglaze HVAC 7 07-05-2017 06:14 AM
Lennox condenser won't start, but the blower runs HankCubs16 HVAC 19 08-18-2016 06:13 AM
A/C Condenser woes kawahonda HVAC 55 07-31-2016 04:03 PM
Any Issues: Old Condenser - New System? JulieMor HVAC 3 07-05-2012 07:57 PM
Condenser Fan Quits After approx 10 min kdogg HVAC 5 08-06-2008 06:03 PM
