Ok To Re-route Vent With PVC To Fit Medicine Cabinet? - HVAC - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By nelaco
  • 1 Post By nelaco
  • 1 Post By surferdude2
Old 12-14-2019, 10:08 AM   #1
Rewards Points: 60
Ok to re-route vent with PVC to fit medicine cabinet?
Hi, I just cut the drywall to fit a 50"wide x 26" tall medicine cabinet. When I made a hole to pull the drywall I found a vent pipe right in the middle of it. Is it ok to cut it and re-route it to the left around the cabinet hole with PCV pipe? If not, can you think of any other solution? It is a small bathroom so surface mount is not an option...it would stick out 5" and the side would face the entrance to the bathroom. Looks like the diameter of the copper pipe is 2" by the way. Thank you for your help in advance.
Ok to re-route vent with PVC to fit medicine cabinet?-pipe-behind-wall.jpg   Ok to re-route vent with PVC to fit medicine cabinet?-wall-cut.jpg
nelaco is offline   Reply With Quote
Old 12-14-2019, 10:14 AM   #2
Rewards Points: 2,782
Re: Ok to re-route vent with PVC to fit medicine cabinet?
LOL, modify the medicine cabinet so the vent passes right through it.
Maybe,
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is online now   Reply With Quote
Old 12-14-2019, 10:16 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,220
You can move it, but if you are going a stud bay over, that it too big to just cut through the stud.
Old 12-14-2019, 10:23 AM   #4
retired framer
Rewards Points: 15,210
How many studs are you going to cut, are you sure it is not a load bearing wall?
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 12-14-2019, 10:24 AM   #5
Rewards Points: 60
Ok, I'll move it to the left....I'll just cut at the bottom and top of the copper pipe, and make a "U" to the left using PVC pipe and elbows. There is a stud to the left that I need to remove anyway to be able to install the cabinet. Thank you for the quick help!
Nealtw, I have to cut 3 studs. The wall runs parallel to the joists so my understanding is that they are NOT load bearing. Any other way to know? There is nothing above the bathroom except the flat roof.
Old 12-14-2019, 10:30 AM   #6
retired framer
Nealtw, I have to cut 3 studs. They run parallel to the joists so my understanding is that they are NOT load bearing. Any other way to know? There is nothing above the bathroom except the flat roof.
That should be fine but you should remove an extra three inches in height so you can put a 2x4 across the top and bottom, you don't want 4 ft of unsupported studs.
figure 7-14
Old 12-14-2019, 10:43 AM   #7
Rewards Points: 60
Ok, I'll do that and build a box all around it then. Thank you for the quick help!
Nealtw likes this.
Old 12-14-2019, 11:00 AM   #8
retired framer
Your top and bottom plates should reach the full studs on the sides
figure 7-14
Old 12-14-2019, 11:05 AM   #9
Rewards Points: 60
[QUOTE=Nealtw;6006743]Your top and bottom plates should reach the full studs on the sides
Ok, thank you for clarifying and the video.
Nealtw likes this.
Old 12-15-2019, 10:10 AM   #10
Rewards Points: 80
When rerouting the vent, make sure that you maintain a decent slope on the horizontal parts, although with your case it won't be far.
PS. That's plumbing not HVAC.
Cheers!
supers05 is offline   Reply With Quote
Old 12-15-2019, 11:52 AM   #11
Rewards Points: 482
Since this is a plumbing question and I'm just an hvac guy, I have a question.
How would he go from copper to pvc? Do they make rubber couplings with hose clamps that are made for and acceptable for this purpose?
bfrabel is offline   Reply With Quote
Old 12-15-2019, 12:18 PM   #12
retired framer
Yes Fernco couplings.
https://www.thepondoutlet.com/fernco-couplings
figure 7-14
Old 12-15-2019, 03:34 PM   #13
surferdude2's Avatar
Rewards Points: 590
Copper venting is something I haven't seen much of. I don't blame the OP for wanting to adapt it to ABS for his project. Sweating that size copper will take more than the average homeowner will be able to do with a Bernzomatic torch, even if using a turbo tip torch and Mapp gas.
I'd use long radius 90 ells just in case some sad day I'd need to run a drain snake down that vent. Probably overkill but that's how I roll. YMMV
Nealtw likes this.
surferdude2 is online now   Reply With Quote
