Nut In Taco Circulator - HVAC - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Questnyc
Old 02-28-2020, 10:51 PM   #1
Rewards Points: 32
Nut in Taco Circulator
Hello Guys. Im replacing my power flo circulator pump with a taco pump. Does anyone know the type of nut goes on the inside of the taco pump and holds on to the power supply? Im not sure if I explained it right but hopefully someone knows what im talking about. Thanks
Questnyc is offline   Reply With Quote
Old 02-29-2020, 06:35 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 6
Re: Nut in Taco Circulator
Ayuh,.... Just a stamped steel conduit fitting nut,.....
Old 02-29-2020, 08:43 AM   #3
Rewards Points: 32
Oh yes. Thank you!!! One last question. Is there a standard size and if so do you know what size I will need? Thanks again
Old 02-29-2020, 10:46 AM   #4
surferdude2's Avatar
Rewards Points: 932
It would normally be a 1/2" conduit locknut. They are available at all the big box stores.
surferdude2 is offline   Reply With Quote
Old 02-29-2020, 11:03 AM   #5
Rewards Points: 32
Thanks guys
surferdude2 likes this.
Old 03-01-2020, 08:50 PM   #6
Rewards Points: 32
Im back with another question. lol. So i successfully replaced my circulator. I drained about a bucket full of water from the boiler in order to install but Im sure there was more to drain. After installation i opened up all the shut off valves, turned on the boiler, and it started to repressurize from 0 to 25 psi until it reached the set temperature of the thermostat and slowly dropped back down to 12 psi (normal pressure).
My question is that i didnt add water back to the boiler manually (just opened up the valves that where closed), how does the system get back to 12 psi (its normal value)?
Old 03-01-2020, 09:09 PM   #7
Rewards Points: 748
Should have an automatic fill valve, that should have been one of the valves you shut to change the circulator.
12 PSI is a hair on the low side for a hot boiler.
roughneck is online now   Reply With Quote
Old 03-01-2020, 10:41 PM   #8
Rewards Points: 32
Oh ok I see it. Whats a good range to set it to? I live in a 2 story house. How does the low pressure affect the heat?
Old 03-01-2020, 11:23 PM   #9
Rewards Points: 932
The law of physics would say you need another 4 psi for a 2 story house. With that, 15 psi would be a reasonable setting.
Old 03-02-2020, 12:09 AM   #10
Rewards Points: 32
Gotcha. Thx
