No Flange On Register Boot? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-04-2020, 09:18 AM   #1
Rewards Points: 386
No flange on register boot?
Have to add new vent to a room I'm redoing as the old one was done poorly. I had gotten some advice to use a boot with a flange but the store didn't have any and I would rather not wait for shipping.
I'm also guessing since nothing in store had a flange it's not as common. Am I supposed to cut the end and fold back flanges? Don't I need something for the grille to screw into? I'm guessing this is a simple question but couldn't figure out the correct Google wording. Thanks!
bcemail is offline   Reply With Quote
Old 09-04-2020, 05:41 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 260
Re: No flange on register boot?
Often the flanges on the boots are split on the corners for the bend. If you need the flanges wider, you can cut the notches deeper and carefully bend the metal .
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
