Nest Thermostat Connecting To Furnace - HVAC - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By user_12345a
Old 09-16-2020, 09:11 PM   #1
Rewards Points: 2
Nest thermostat connecting to furnace
Hey everyone
Trying to update my thermostat
Since my old thermostat didn't have a c wire thought I'd try the G trick where you attach it to the C on both the thermostat & furnace
Well I opened up my furnace and I have a joined wire that connects to the c already and a yellow that attaches to Y with the original from the thermostat
After some research found out this is for the outside unit
Can I still take the G wire and double up on the C at the furnace and use the other end for the C in the thermostat????
Help this DIY guy out !!!
Dave
Garland30 is offline   Reply With Quote
Old 09-16-2020, 09:13 PM   #2
Re: Nest thermostat connecting to furnace
Buy an add a wire kit. They sell on amazon
jmal1031 is offline   Reply With Quote
Old 09-16-2020, 09:41 PM   #3
Rewards Points: 724
Run new wire, or better yet ditch the Nest before it causes you lots of headaches. They have and cause a lot of problems. Which are amplified without a common or using an add a wire devices.
roughneck is online now   Reply With Quote
Old 09-16-2020, 09:45 PM   #4
user_12345a's Avatar
Rewards Points: 52
if u want something decent that's similar (actually better) in features get the ecobee instead. it comes with an add a wire style kit specifically made for the stat that's less likely to cause problems.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
Old 09-16-2020, 09:51 PM   #5
Rewards Points: 902
If you've already purchased the Nest you can try the G wire trick, might work ok for you. You have to install the jumper to get the fan to come on while there is a call for cooling.
57TinkerMan is offline   Reply With Quote
Old 09-16-2020, 09:57 PM   #6
Rewards Points: 52
^for nest and similar consumer products there's also the hammer trick.
57TinkerMan likes this.
Old 09-17-2020, 11:08 AM   #7
Rewards Points: 314
Hi, I like the hammer trick, how difficult would it be pull a new thermostat cable? it would be a better option than trying to MM it with add on’s or jumpers.
JMO
Geo
Geochurchi is offline   Reply With Quote
Old 09-17-2020, 12:51 PM   #8
Rewards Points: 52
Depends on your house - if you have to pull wire through finished areas beyond one partition wall it could be difficult.
