Need New 4 Ton 14/16 SEER Unit - HVAC - Page 4 - DIY Chatroom Home Improvement Forum
Like Tree8Likes
Old 08-04-2020, 03:44 PM   #46
Rewards Points: 716
Re: Need new 4 Ton 14/16 SEER unit
Quotes aren’t usually itemized.
This is where you have to interview the installer to see what quality of work they do.
Like purge with nitrogen while brazing, do a proper leak test and evacuation with a micron gauge, and perform a proper equipment commissioning once the installation is done.
roughneck is online now   Reply With Quote
Old 08-04-2020, 04:00 PM   #47
An old Tradesmen
Rewards Points: 54
Originally Posted by PBJ* View Post
The tech said going 3.5 ton would be a disservice and going above 4 would not effectively remove humidity
He quoted me the same Lennox Elite 4 ton as the other company.
Dropping to 3.5 tons would be a nominal capacity drop of 12.5%. Increasing to 5 tons, would be a nominal capacity increase of 125%.
Old 08-04-2020, 04:04 PM   #48
An old Tradesmen
Rewards Points: 54
And he lost his damn mind... $5800!! Lol
That 10 year labor warranty, was a warranty you were being charged for.
My setup is the easiest. Itís in a closet , the lines go up and over the wall, not underground, itís on a stand... not attic or anything crazy to run
Okay. Go to the closet, and poke your head around the back of the air handler and tell us what it looks like.
Old 08-04-2020, 04:18 PM   #49
Rewards Points: 16
Yea I figured he buried it in the offer....
I put my head back in the closet and itís very dark ...
PBJ* is offline   Reply With Quote
Old 08-04-2020, 04:22 PM   #50
Rewards Points: 16
Old 08-04-2020, 04:26 PM   #51
An old Tradesmen
Rewards Points: 54
You see how little room there is to work. Its not quite as easy as you think.
How easy do you think it will be to seal the duct to the back of the air handler.
Old 08-04-2020, 04:27 PM   #52
Rewards Points: 16
I am repeating what a tech said to me today, I do not infer it is easy work on my own accord.
Old 08-04-2020, 04:32 PM   #53
An old Tradesmen
Rewards Points: 54
I am repeating what a tech said to me today, I do not infer it is easy or wick on my own accord
Lots of techs have a good talk to get a job. But not the skill to back it up.
A poor job in that closet will leave you with a very sour taste in your wallet.
Old 08-04-2020, 04:43 PM   #54
raylo32's Avatar
Rewards Points: 2,166
I dunno about that. My mom lives in FL and her condenser is on a stand outside and that is easy peasy. But the air handler in a closet and if yours is anything like hers it is a nightmare install. There is absolutely no room to work, like they put it in with a shoe horn. The last time it was replaced they had to come back several times to fix drywall and wood trim.
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 08-04-2020, 07:09 PM   #55
Rewards Points: 16
I guess the new ďthingĒ is a free UV light installed in the air handler...
