Need Help Figuring Out Error Code On Carrier Furnace. - HVAC - DIY Chatroom Home Improvement Forum
Old 02-10-2020, 09:54 AM   #1
Rewards Points: 8
Hi everyone. I have a Carrier furnace that is behaving erratically. It works during the day when the temperature is not too cold but it does not work at night when it is cold. I went to the attic to check it and I see the blinking led but I am not sure as to how to figure it out. The sequence seems to be short blink, long blink and immediately three short blinks.
griera is offline   Reply With Quote
Old 02-10-2020, 10:00 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 162
Re: Need Help Figuring Out Error Code On Carrier Furnace.
There should be a sticker on the front or back of one of the doors with a legend with the code.
First digit is the short blinks and the second digit is the long blinks.
Post the model # of the furnace.
Look in : view yuri's album under my avatar pic and I have a basic Carrier legend in there with some codes.
Old 02-10-2020, 10:19 AM   #3
Rewards Points: 8
Here is a link to a video of the blinking led.
The model number is CK5BXT04.
Old 02-10-2020, 10:35 AM   #4
Rewards Points: 716
Should be a code schematic listed on the furnace.
Need the model number for the furnace. That one is the evaporator model.
roughneck is online now   Reply With Quote
Old 02-10-2020, 10:42 AM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 162
That is a code 14 meaning ignition lockout.
I would start by cleaning your flame sensor. It should look similar to the one in this video.
Use clean steel wool or #400 emory paper. A dollar bill may not have enough grit in it but can do in a pinch.
Old 02-10-2020, 10:49 AM   #6
Rewards Points: 8
Yes there is a sticker showing the codes but I am confused as it states that the first digit is determined by the short blinks and second digit by long blinks but I get one short, one long and three short blinks again which is confusing.
The model number I provided is the only sticker with a model number I can find. I'll check again and will post it.
Old 02-10-2020, 12:03 PM   #7
Rewards Points: 716
Model number will be in the burner compartment
Old 02-10-2020, 12:47 PM   #8
Rewards Points: 8
I cleaned the flame sensor as suggested. The furnace is working for now but will see how it behaves at night.
Thanks for your help.
