Moving AC Unit Without Disconnecting The Wires - HVAC - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By user_12345a
Old 08-10-2020, 11:29 PM   #1
Rewards Points: 50
Moving AC unit without disconnecting the wires
This may not sound very wise but what is the likelyhood of the wires breaking if I was to lift the AC unit 4-5 ft so I can form concrete pad? Its sitting on temp packed gravel and some natural stone leftover slabs. I was planning to lay sod and I dont want to work with concrete after sod is in.
limiteddi is offline   Reply With Quote
Old 08-11-2020, 12:03 AM   #2
user_12345a's Avatar
Rewards Points: 76
Re: Moving AC unit without disconnecting the wires
The wires aren't a big deal at all, it's the refrigerant lines. They're easy to disconnect if required, just need to be safe.
Unless your lineset has slack/is much longer than necessary outside, you'll need to call someone to pump the refrigerant in the indoor coil and lines down/into the condenser and disconnect.
Lots of $$ and if you can avoid doing this concrete work until the a/c needs to be replaced, you should.
Chris130 likes this.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old 08-11-2020, 09:09 AM   #3
surferdude2's Avatar
Rewards Points: 924
Why so high... I'd think you could get by with 4 or 5 inches not feet, in which case it might be possible.
Ah, but I was so much older then...I'm younger than that now
surferdude2 is offline   Reply With Quote
Old 08-11-2020, 09:43 AM   #4
Rewards Points: 1,896
Far less work to just install a preformed pad.
https://herculesequipmentpads.com/
Old 08-11-2020, 10:03 AM   #5
dj3
Rewards Points: 208
I would wait till the condenser needs replacing (which could happen sooner than you think, judging by today's lack of quality standards).
dj3 is offline   Reply With Quote
Old 08-11-2020, 03:31 PM   #6
Red Seal Electrician
Rewards Points: 506
Concrete slabs on gravel work fine.
My HVAC guy's bill was ~$1200 to pipe, reconnect, and charge the condensor unit after moving it 12 feet. (I did the electrical).
u2slow is offline   Reply With Quote
Old 08-11-2020, 04:09 PM   #7
raylo32's Avatar
Rewards Points: 2,194
Once upon a time I raised mine about 2 feet and propped it up there to get it off the ground and onto the new deck I was building. I don't think it would have gone 4 or 5 feet, however, without damaging the refrigerant lines.
Live long and prosper.
raylo32 is online now   Reply With Quote
