Mounting Brackets Are Broken Off The Blower Motor Chassis - HVAC - DIY Chatroom Home Improvement Forum
Old 06-23-2020, 08:34 PM   #1
Rewards Points: 792
Mounting brackets are broken off the blower motor chassis
it seems that the mounting brackets are welded to the motor chassis. Can I insert a new mounting bracket onto the chassis.
any other suggestion would be appreciated.
Mounting brackets are broken off the blower motor chassis-20200623_210146.jpg   Mounting brackets are broken off the blower motor chassis-20200623_210200.jpg
form8829 is offline   Reply With Quote
Old 06-23-2020, 08:48 PM   #2
Rewards Points: 894
Re: Mounting brackets are broken off the blower motor chassis
Torsion flex mounting. You can purchase a new bracket, you would have to grind off the old brackets to get it to fit. Might be worth your while to just buy a new motor. Motors and brackets in link below:
https://www.supplyhouse.com/sh/contr...ex+mount+motor
57TinkerMan is offline   Reply With Quote
Old 06-25-2020, 08:25 PM   #3
Rewards Points: 792
thanks
Old 06-25-2020, 09:43 PM   #4
user_12345a's Avatar
Rewards Points: 46
It's possible the brackets broke for a reason - for example, out of balance vibrating blower wheel. It's not normal to have that happen.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
Old 06-26-2020, 05:44 PM   #5
Rewards Points: 792
thanks user_12345a
Old 06-26-2020, 07:35 PM   #6
dj3
Rewards Points: 112
Is the motor noisy? Does it vibrate?
dj3 is offline   Reply With Quote
Old 06-27-2020, 06:23 PM   #7
Rewards Points: 792
it appears that the blower assembly was not wide enough and the sides were not under tabs of the furnace. it had tape on it to cover the waps and some of the tape was sucked in to the blower wheel.
I will probably have to get one that is the right side.
