Mini Split Install - HVAC - DIY Chatroom Home Improvement Forum
Old 07-21-2020, 06:58 PM   #1
Rewards Points: 4
Mini split install
I am in the process of installing 3 separate mini split systems to my place. Question I have is do I need to install 3 separate breakers for each unit and disconnect or can I install 3 separate disconnects using one breaker off main panel. Each unit pulls 22 amps.
Ecgraham5268 is offline   Reply With Quote
Old 07-21-2020, 07:06 PM   #2
Rewards Points: 714
Re: Mini split install
Separate circuits for each.
roughneck is offline   Reply With Quote
The Following User Says Thank You to roughneck For This Useful Post:
Ecgraham5268 (07-21-2020)
Old 07-21-2020, 07:12 PM   #3
Rewards Points: 4
That’s what I thought. Thanks. Just trying to save a little wiring if possible but again what I thought. Thanks for the help
