Looking For A Compatible Thermostat To Existing (old) Unit - HVAC - DIY Chatroom Home Improvement Forum
Old 02-10-2016, 12:53 PM   #1
Rewards Points: 26
Looking for a compatible thermostat to existing (old) unit
Hey gang - I've gone through 3 different digital Home Depot thermostats and I keep running into the same issue. I have an old thermostat in our basement that controls the baseboard heat from our oil burning furnace. It no longer works and I want to replace it with a new one. I don't need anything fancy.
The problem I am running into is the wiring. On the old unit, you'll see there is a white wire connected to a "6-six" terminal (see arrow in image). And on all three of the new ones I tried, none of them has a 6-six terminal.
I've done extensive research online but can't really find anything as to what this terminal is or what it would become on a new unit.
Does anyone have any suggestions on what I can do here? What terminal would that white wire go to on a new unit? Or alternatively, are there any basic thermostats out there that still have a 6-six terminal available?
Appreciate any advice you have. Thank you!
Looking for a compatible thermostat to existing (old) unit-vzm.img_20160210_115336.jpg
john123drury is offline   Reply With Quote
Old 02-10-2016, 01:07 PM   #2
Rewards Points: 907
Try googling White Rodgers 1F90.
Bitters is offline   Reply With Quote
Old 02-10-2016, 02:04 PM   #3
Rewards Points: 26
Thanks Bitters. I took a look and it seems a bit pricey for my budget. Anything else in the "less than $50.00" range you might be able to recommend?
Old 02-10-2016, 04:40 PM   #4
Rewards Points: 1,226
Long term, you probably want to know what options you can implement for when this IF90-82 is not available but--for the immediate--how about this: http://www.ebay.com/itm/White-Rodger...sAAOSwzhVWsgyp
bfletcher7 is offline   Reply With Quote
Old 02-10-2016, 05:00 PM   #5
Rewards Points: 907
I should have been clearer. That's the stat you have now. Might be able to find a manual so you can identify 6-six terminal. Can you post a pic of the stat wires in the furnace?
Old 02-10-2016, 05:10 PM   #6
Rewards Points: 26
Thanks bfletcher. That's the exact model I have now. Not a fan of it whatsoever. But this gives me an option if I'm unable to locate a newer model replacement. Appreciate it!
Old 02-10-2016, 05:11 PM   #7
Rewards Points: 26
I'm sure I can. Give me a few days and I'll post a pic of the connections at the furnace. Thanks!
Old 02-10-2016, 05:33 PM   #8
Might this post be of any value to those trying to help you?
https://community.nest.com/thread/12130
Old 02-10-2016, 06:25 PM   #9
Rewards Points: 692
What is this thermostat controlling?
Do you have a zoned hydronic system -> http://www.justanswer.com/hvac/8c23a...der-model.html
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
Old 02-14-2016, 08:58 AM   #10
Rewards Points: 26
Hey guys just an update: I decided to go with the same model thermostat for the time being. Should arrive in a few days. I am baffled (and a bit concerned though) because the baseboard heating downstairs is still on. The pipes are hot and the room is warm. It makes no sense to me because I have disconnected and taped up all three wires, and none of them are touching each other. Any thoughts?
Old 02-14-2016, 11:09 AM   #11
Rewards Points: 80
If you have a similar model to the nest post above, the valve is driven both open and closed. (no spring return) So unless it's intentionally closed, it'll stay open, allowing water to flow.
If this is true, to use a conventional stat you'll need a relay.
Cheers!
supers05 is offline   Reply With Quote
How can I wire a 5 wire thermostat from 2 existing ones? PeteSki HVAC 10 11-22-2015 01:39 PM
Thermostat wire to Condenser unit. Where? bodale HVAC 9 10-03-2014 01:51 PM
Unit will not turn off. Contactor, thermostat, or other? TexasPeace HVAC 2 09-02-2013 06:46 AM
Thermostat for electric baseboard wiring help needed vae_victis HVAC 10 01-05-2012 11:53 AM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
