Looking For 110v Ducted Mini Split Air Handler - HVAC - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By DeskDrawer
Old 04-14-2020, 10:24 AM   #1
Rewards Points: 14
Looking for 110v ducted mini split air handler
Does anyone know if there's such a thing as a ducted mini split air handler that runs off of 110v? All the ones I'm seeing seems to require 200+ volts.
Thanks!
DeskDrawer is offline   Reply With Quote
Old 04-14-2020, 11:38 AM   #2
user_12345a's Avatar
Rewards Points: 76
Re: Looking for 110v ducted mini split air handler
You probably won't find one.
Why is there an issue getting 240v?
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old 04-14-2020, 12:27 PM   #3
Rewards Points: 738
No, the ones I’m aware of are all 208/230V.
Is this for your mobile application in your other thread?
roughneck is offline   Reply With Quote
Old 04-14-2020, 12:53 PM   #4
Rewards Points: 14
Thank you both for the reply.
Sorry I forgot to mention that this isn't for a house, it's for an RV.
Yep!
Old 04-14-2020, 01:02 PM   #5
Rewards Points: 76
Can you get a 220/240v inverter?
otherwise, you're looking at a rv a/c or self contained window unit.
Old 04-14-2020, 03:50 PM   #6
Rewards Points: 14
Hmm, that's a thought. I'll look into it. Thanks!
Old 04-14-2020, 09:40 PM   #7
Rewards Points: 738
Yeah, I’d look into a 208/230V inverter.
Total amp draw will be lower. A unit will be much easier to find as well.
Old 04-15-2020, 08:12 AM   #8
Rewards Points: 3,298
Pardon me if I'm being an idiot...but is this what you're talking about?
https://www.pioneerminisplit.com/pro...14703001468970
To the optimist, the glass is half-full.
To the pessimist, the glass is half-empty.
To the engineer, the glass is twice as big as it needs to be.
DIYOkie is online now   Reply With Quote
Old 04-15-2020, 08:43 AM   #9
Rewards Points: 14
Kind of - that system has a "ductless" air handler. I'm looking for a ducted, which looks like this:
https://www.pioneerminisplit.com/pro...ystem-full-set
DIYOkie likes this.
