LG Mini Spilt - Cut Lines, Subtract Refrigerant? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-12-2020, 06:42 PM   #1
CedarWood's Avatar
Rewards Points: 50
LG Mini Spilt - Cut lines, subtract refrigerant?
I am installing a 18k Single Zone LG mini spilt system (LS180HSV5). The instructions are not entirely clear on what to do if you cut your lineset? It looks like the factory compressor charge should be good up to 32.8ft according to the table for the LS180. I will be cutting my lines down to about 17-18 ft and having someone help me do the flared connections. Should I be concerned about having too much refrigerant in the system?
LG Mini Spilt - Cut lines, subtract refrigerant?-screen-shot-2020-04-12-4.36.45-pm.png   LG Mini Spilt - Cut lines, subtract refrigerant?-img_0607.jpeg
CedarWood is offline   Reply With Quote
Old 04-12-2020, 08:21 PM   #2
Rewards Points: 716
Re: LG Mini Spilt - Cut lines, subtract refrigerant?
No, you should be ok.
Just make sure to do a proper leak test and evacuation. Most issues with minis are due to leaks due to improper installation techniques.
roughneck is offline   Reply With Quote
The Following User Says Thank You to roughneck For This Useful Post:
CedarWood (04-12-2020)
