Lennox Part Id. This Might Take An Industry Professional. - HVAC - DIY Chatroom Home Improvement Forum
Old 04-07-2020, 12:51 PM   #1
Rewards Points: 68
Lennox part id. This might take an industry professional.
Please see the photos. The entrance orifices of my heat exchanger (5 orafices) have what appears to be a fire retardant fabric. My best guess is that this is some kind of flame diffuser. What is this white fabric and what is it called. Better yet do you have a part number for the fabric inserts? The fabric in my unit here has deteriorrated and I want to replace it. Thank you.
Lennox part id. This might take an industry professional.-00m0m_ggghabylmgs_1200x900_1586281225807.jpg   Lennox part id. This might take an industry professional.-00b0b_8k1ho1vv04l_600x450_1586281299107.jpg   Lennox part id. This might take an industry professional.-00x0x_e9qk8eajy46_600x450_1586281336035.jpg
hotrodjohn71 is offline   Reply With Quote
Old 04-07-2020, 04:33 PM   #2
Rewards Points: 918
Re: Lennox part id. This might take an industry professional.
My guess is that they are Low NOx inserts. If you look closer I think you will see that the "fabric" is protecting the end of the insert (metal screen). Don't know the part number. If you're not in California or location that requires them for emission control you may be able to remove them. Best to check with a Lennox dealer before doing that.
57TinkerMan is offline   Reply With Quote
The Following User Says Thank You to 57TinkerMan For This Useful Post:
hotrodjohn71 (04-08-2020)
Old 04-08-2020, 10:10 AM   #3
Rewards Points: 68
Thank you 577. Do you know how the screen and fire retardant fabricks effect the NOx?
Old 04-08-2020, 10:28 AM   #4
Rewards Points: 918
Simple explanation below:
https://hvacrfundamentals.blogspot.c...hos-there.html
Old 04-08-2020, 11:23 AM   #5
user_12345a's Avatar
Rewards Points: 128
I would just get rid of them - california government bs.
on another forum people were saying that they reduce the efficiency and btu output by cooling the flame and carbon monoxide can actually be increased.
reduce nox at the expense of increasing co emissions and fuel consumption - sounds like a great plan, courtesy of the idiots who legislated putting cancer warnings on coffee.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
The Following User Says Thank You to user_12345a For This Useful Post:
Old 04-08-2020, 12:00 PM   #6
Rewards Points: 68
Ok, great. So if I remove them then the system should still work? I'd rather not replace them if they're not necessary.
Old 04-08-2020, 12:04 PM   #7
Rewards Points: 128
the furnace will work fine without them if they are indeed low nox inserts.
i don't know if removal in an existing appliance is legal or not in your area.
