Leak In High Efficiency Furnace - HVAC - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By diyorpay
  • 1 Post By beenthere
Old 01-27-2020, 10:05 AM   #1
Larryh86GT's Avatar
Rewards Points: 238
Leak in High Efficiency Furnace
I found this leak happening in my son's furnace yesterday.
The 2 bolts (just screwed into plastic) holding the white pvc
pipe to the black blower motor were not sealing the pipe and
there was a constant drip. Are the 2 bolts normally nutted to
hold? I replaced the 2 bolts with bolts with washers and nuts
and stopped the leak. I am guessing that the exhaust gas
may have been leaking out also? Your thoughts?
Larry
Larryh86GT is offline   Reply With Quote
Old 01-27-2020, 02:31 PM   #2
Rewards Points: 30
Re: Leak in High Efficiency Furnace
Can't comment on how much carbon monoxide may have also leaked a bit.
But, right behind silver clamp, notice a bit of black schmutz. That's because there used to be a pliable type black putty where the pvc meets the backside of the clamp. You've solved the condensate drip. Now for safety, make a snake like bead of putty to place around the pipe and press into position. If you are a silicone insister, 100% silicone globbed all the way around will also work.
It appears this may not be the original induced draft fan. Whoever swapped in a new one didn't follow instructions.
Putty or silicone on both sides of clamp wouldn't hurt.
Larryh86GT likes this.
diyorpay is offline   Reply With Quote
Old 01-27-2020, 05:59 PM   #3
An old Tradesmen
Rewards Points: 140
Some CO was also coming out. How much, no one can say for sure.
Usually, the bolts/screws just grab the metal flange.
